Go Back   CNCzone.com-The Largest Machinist Community on the net! > Mechanical Engineering > Linear and Rotary Motion
Linear and Rotary Motion Discuss ball/Acme screws, R&P, linear slides and theory here.
Old 02-22-2006, 02:07 PM
WilliamD is on a distinguished road
Lead screw mech adv
I was wondering if they diameter of the lead screw made any difference as to the mechanical advantage. Also, how do you calculate mechanical advantage. If I have 50 oz at the motor, on a 10:1 ACME, is that 500 oz, minus half for efficiency, so 250 oz at the spindle? Just trying to finalize me router setup and tune it to what I need. Thanks in advance!
Old 02-22-2006, 03:06 PM
WhiteTiger is on a distinguished road
www.roton.com has reference and advisory pages for acme and ballscrew. You can find pretty much all of what you want there, I think.
Btw, if the pitch is the same then yes a larger diameter will have a lower thread angle and greater mech adv. Unrolled, it's a shallower ramp, so more travel, less force for the same lift.
Tiger
Old 02-22-2006, 03:18 PM
mike hide is on a distinguished road
acme threads
Just wondering are buttress threads ever used ? that way the cutter head could cut on the way out and the way in .I think acme threads are for thrust loads in one direction.
Old 02-22-2006, 03:27 PM
Just bass ackwards. Buttress are for loads one direction only while acmes are symetrical at 14.5 degree pressure angle. Buttress look like the teeth on a handsaw: near vertical load face and ramped away on the back side.
I've used buttress more than once in building custom rifle actions. Hard to beat for one direction loads, especially where radial distances are tight.
Tiger
You have it backwards.
