Go Back   CNCzone.com-The Largest Machinist Community on the net! > Mechanical Engineering > Linear and Rotary Motion
Linear and Rotary Motion Discuss ball/Acme screws, R&P, linear slides and theory here.
Old 02-20-2006, 09:56 PM
CarveJunky is on a distinguished road
Mounting ball nuts
I am about ready to do the final assembly on my mill conversion, one aspect of the assembly still puzzles me. I did a search to see the correct way to mount the ball nuts. According to the THK site the correct way is with the return tube facing down, to reduce torque inconsistency caused by the balls hitting in the return. However I have seen images of assemblies with the return tube rotated 90°, and have also seen the return tubes facing the top in a BP yoke assembly.
I would like to know definatively, is there a correct position for the returns? Is there really a big enough concern over the balls making contact in the returns to cause fuctuations in the torque? Would this be a concern only if you were using marginally sized motors for you axis? Any help would be greatly appreciated.
CarveJunky
Old 02-20-2006, 10:30 PM
ViperTX is on a distinguished road
Well...on my Danaher ballnuts the tube is diagonal.....so the return end depends on the direction you are turning the ballscrew. The inportant thing is to have the returns on the vertical sides and not the horizontal sides.
