Go Back   CNCzone.com-The Largest Machinist Community on the net! > Mechanical Engineering > Linear and Rotary Motion
Linear and Rotary Motion Discuss ball/Acme screws, R&P, linear slides and theory here.
Old 01-29-2006, 10:08 PM
High Seas's Avatar
Gold Member
High Seas is on a distinguished road
Racks and Spur Gears -- HP Laserjet Motors
Regarding HP Laser Jet motors and similar such recycled motorrs
Does anybody know what the pitch of the spur gear is on these motors?
14.5 and 20 seem to be the common for spurs & racks (McMaster-Carr seems so) and I was wondering if I could just drive a motor down the rack with the existing gear.
Is there an easy way to find out ? Without buying a tool or rack?
(This seemed more like a mechanical issue and less a "motor" one thats why I posted here) Thanks - and,
Jim
Experience is the BEST Teacher. Is that why it usually arrives in a shower of sparks, flash of light, loud bang, a cloud of smoke, AND -- a BILL to pay? You usually get it -- just after you need it.
Old 01-29-2006, 11:03 PM
HayTay's Avatar
HayTay is on a distinguished road
Jim,
The gearing on the shaft of an HPLJ-II/III stepper motor is not straight, it is in a spiral. See attached picture. All of the spurs & racks on McMaster-Carr's website appear to have straight gearing. Maybe I was looking in the wrong section. Do you have any specific M-C part numbers?
HayTay
Name:	Motor - Side.JPG‎
Old 01-29-2006, 11:29 PM
High Seas's Avatar
Gold Member
HayTay -- Yer Right!
I was looking at the wrong stepper (picture) and thinking it was an HP. Sooo, if I get to the HPs - then looks like its pull/adapt that gear and get the M-C gear and rack as a set.
Still wonder about the other Epson etc (junk) motors and bits though. Maybe the easiest is to use the belts that came off the printers with them. Thanks for the quick comeback.
Jim
Old 01-29-2006, 11:35 PM
HayTay's Avatar
After Googling gears & such, I have discovered that the type of gearing on the shaft of an HPLJ-II/III stepper motor is known as a "Helical Gear".
Check out the following links:
Atlanta Drive Systems
Qualty Transmission Components
KHK Co., Ltd.
Learned something new today,
Thanks,
HayTay
Old 01-30-2006, 02:05 PM
High Seas's Avatar
Gold Member
HayTay! Great sites - thanks. BUT - Now I still gonna have to figure out the pressure angle and helix angle on the HP motors. Oh yeah and Left/Right pitch. Maybe easier to pull and replace the gear. I'm sure you saw the app I was thinking of--the motorand gear right on the rack. I was googling down the wrong set of gears! Thanks again, and
Jim
Old 01-30-2006, 03:42 PM
Mcgyver is on a distinguished road
in likelihood its 20, 14.5 is rather old fashioned but does come up sometimes. then again who knows what they put in them. Also, I bet a rack to match that gear, if you could find it, will not be cheap - was it actually driving a rack??? or just a matching helical gear? I'd be pulling the gear and replacing with standard rack and pinion
edit. well i see on the link helical racks are stock, so maybe it wouldn't be that much more. be interesting to see the cost delta
