| Linear and Rotary Motion Discuss ball/Acme screws, R&P, linear slides and theory here. |
| Hi Hopefully you can help a noob with a design please. I have admired everyones work here and got the CNC bug (that golf trolley painting machine!) I want to build a Pen/Brush Plotter. I presume it wouldn't have to be as heavily built as some of your CNC machines. The purpose of it is to draw outlines onto 40mm deep box canvases. I have 3 steppers and the control electronics (Routout), I just need to sort out a frame and linears for it. I want to base it on a 1m x 1m x 25mm thick piece of MDF with a stainless steel face. I could have it bigger or smaller but I have settled on a convenient size. My design would allow larger canvases to be drawn on if needed but 900mm x 900mm is average. I have attached a sketch. Basically one large round fully supported fixed rail 25mm dia. for the X axis with 2 linear bushings which carry the Y axis of 2 supported 16mm round rails holding 2 bushings to hold the Z axis on. I am ignoring the Z axis for the time being as it will only be holding a pen. The other side of the Y axis will be supported by an idler wheel of different heights so it can ride on a canvas underneath if its bigger than the plotter or just ride on the bed if it's smaller. Both axis will be belt driven. (I have a Roland A3 plotter and though if it's good enough for that?) What do you guys think please? Regards DF |
| Cool - looks fairly low cost - because you keep the weight/loads on the y/z axis down to the pen/brush and drive. Looks like you've supersized one of the scanners I ripped for bits and pieces - and you know they are pretty accurate. Been looking at cheap methods for vinyl cutting and this could be one. Ought to be a quick build too. Thanks for the sketch! I'll be interested on your results - cost/time/precision/repeatability etc. Jimbtw - remember, you'll be giving up a bit at both ends and width of the y axis so it might be a squeeze to get 900x900 worked edge to edge with only the 1 meter rail! 800x800 ought to fit nicely.
__________________ Experience is the BEST Teacher. Is that why it usually arrives in a shower of sparks, flash of light, loud bang, a cloud of smoke, AND -- a BILL to pay? You usually get it -- just after you need it. |
| Cheers Jim, yes I realised about the size, but as the base is open sided, larger canvases can just hang over the edge a bit. When I get the stuff I will do photos and a write up. Thanks Carlo, I have left the Z axis until I get the X and Y running, not thought about it much as I am only drawing on canvas. By stock do you mean the canvases or the plotter base? David |
Carlo |
| You should check out T.E.A. Machine Components, Inc. - www.teausa.net. They carry a wide variety of components. |
