Go Back   CNCzone.com-The Largest Machinist Community on the net! > Mechanical Engineering > Linear and Rotary Motion
Linear and Rotary Motion Discuss ball/Acme screws, R&P, linear slides and theory here.
Old 01-27-2006, 05:03 PM
journeyonline is on a distinguished road
VXB Precision Shafting - can you drill and tap it?
I was looking into the VXB.com linear shafting they sell. Has any one tried to drill and tap it to strenghten the shafting for long spans like 4+ feet or more. They sell it up to 9 feet, its 60 rockwell hardend. I was told you can drill it with carbide. But how about putting a tap in it for supports?
Cost only $500 to do a 5x5' x and y axis.
Any users out there or suggestions.
Old 01-27-2006, 06:03 PM
pminmo's Avatar
pminmo is on a distinguished road
If you can drill it, you probably could use a non tapped post epoxied in trheaded on the other end.
Phil, Still too many interests, too many projects, and not enough time!!!!!!!!
Vist my websites - http://pminmo.com & http://millpcbs.com
Old 04-14-2006, 01:42 PM
ja_ri123 is on a distinguished road
You can drill it but you need carbide drills. After you brake thru hard (~1mm) part it is pretty easy to drill/tap.
Old 04-14-2006, 01:47 PM
Zumba is on a distinguished road
I use a carbide spotting drill and then a 2-flute carbide "Hi-roc" drill.
The first time I tried using a cobalt bit. That was fun. The bit just floated on top spinning. When I raised the quill, the shafting didn't even have a scratch on it.
Old 04-14-2006, 04:06 PM
Enraged is on a distinguished road
check local suppliers as well, we bought 1.5" hardened precision shafts, 12 feet long, drilled and tapped, for CDN$940 with tax. they were packaged as NSK, and cheaper than buying directly from Nook. also, keep in mind that shipping 5 foot steel shafts wont be cheap, as well as having local support if something goes wrong, makes buying local even better.
