Go Back   CNCzone.com-The Largest Machinist Community on the net! > Mechanical Engineering > Linear and Rotary Motion
Linear and Rotary Motion Discuss ball/Acme screws, R&P, linear slides and theory here.
Old 01-19-2006, 07:53 PM
rocks101 is on a distinguished road
Is One Screw Enough
Hi all, we are a group of students working at building a cnc router to help us with our projects. I would like to know if one 5/8 ball screw will be enough to drive the gantry which is 4ft in length and 2 ft high, the gantry is sliding on dual 20mm Igus rails with their polymer bearings.The gantry's foot print is 12" and it has a trave of 36". I have posted a quick rendering of our design below. Any advice is greatly appreciated. Ps the gantry side are 1" thick aluminum plates, and most of the components other components are also aluminum.
Thank you.
Name:	cnc draft 1.jpg‎
Old 01-20-2006, 08:29 AM
2muchstuff is on a distinguished road
Wow, 1" thick aluminum side plates, seems to be a little thick. With a 4' long gantry and a 12" side plate, I would drive it with 2 screws, one on each side. This will prevent racking/twisting of the gantry. The 5/8" screw would be a good size when driven from both sides.
If it's not nailed down, it's mine.
If I can pry it loose, it's not nailed down.
