Go Back   CNCzone.com-The Largest Machinist Community on the net! > Mechanical Engineering > Linear and Rotary Motion
Linear and Rotary Motion Discuss ball/Acme screws, R&P, linear slides and theory here.
Old 01-11-2006, 04:42 PM
phantomcow2 is on a distinguished road
What would a ballscrew like this cost?
A nice ground ballscrew like from NSK or another reputable company.
12mm diameter, 2mm pitch.
Preloaded nut
about 11" of travel
And both ends machined to .25", one with threading to accept a pair of angular contact bearings, the threading to lock their inner races together.
What would i be looking at for cost?
Old 01-11-2006, 08:31 PM
veteq is on a distinguished road
a lot
i asked my thk company for a quote
5mm lead 300mm long and machined
preloaded for the application without support bearings (2axles)
teh same but 1 axle 480mm
all 16mm
3900 dollars
kind regards
Old 01-11-2006, 08:32 PM
Lol
hahahaahah
can i get a bit off money from you, joking
Old 01-12-2006, 12:49 AM
mxtras's Avatar
Silver Member
mxtras is on a distinguished road
Relevant info -
I just purchased two super precision NSK screws of similar dimensions for a machine I designed - recieved them 2 months ago. These were 32mm diameter, 2MM pitch, about 3" of travel, preloaded - 100% custom made. It took 8 months to get them. They were about $4K each. The pitch accuracy was in microns, though - if I recall, the total error down the legth was less than 6 microns away from perfection. These are used to position a mechanical element for a wide web painting process. The company now has 4 of these - two are being re-worked at NSK as we speak. Even re-work costs a fortune - $2800 each minimum.
I know this is the extreme, but the precision screws are the price of a used car.
Scott
Consistency is a good thing....unless you're consistently an idiot.
Last edited by mxtras; 01-12-2006 at 02:05 AM. Reason: Added a few more somewhat relevant details.
Old 01-12-2006, 01:57 AM
Enraged is on a distinguished road
phantom, if you want something lower cost, check mcmaster.com or roton.com
mcmaster lists 5/8" ballscrews at around $1.27 per inch, and square ballnuts to match are around $23. just search for ballscrew on the left side of the page, and they should come up. granted they wont be as accurate as a ground thk ballscrew, but they will be 1/100th the cost.
Old 01-12-2006, 05:38 AM
Thankyou very much folks
Old 01-12-2006, 06:36 AM
TommyB is on a distinguished road
Check out misumi.com, i have ordered a set of ballscrews from them and they appear to be of very good quality. For what your asking for, I quickly saw it would cost you about $500 for C3 grade. You can specify any length and any end configuration, it is included in the price. Some modifications will cost a bit more, but very reasonable, like $14 for a keyway. I attached the pdf I had from them when i was ordering.
Old 01-12-2006, 07:39 AM
Switcher's Avatar
Moderator
Switcher is on a distinguished road
TommyB,
Was that supposed to be: ------> http://www.misumiusa.com/ <------?
