| Linear and Rotary Motion Discuss ball/Acme screws, R&P, linear slides and theory here. |
I recall seeing a guy on this forum make his CNC router using delrin as linear bearings. Just delrin bored perfectly to size, sliding over drill rod or whatever other shafting. Well i cant find that again, so i thought i would ask; Is this a good idea? I am in the process of making a CNC router and was going to go the skate bearing route, but if this has been known to work well, i will use delrin instead. It would be sliding on 2.25" diameter shafting, and 1.25" shafting |
| Had not looked at prices until a few minutes ago. I think for that cost i might as well go for linear bearings! Looks like the old skate bearing route is the way im going then. Plus ive already machined many parts for my skate bearing setup, so i suppose its for the best. |
http://www.cnczone.com/forums/showpo...1&postcount=74
__________________ Mark -------------------------- Check Out My Build-Log(s): http://cnczone.com/forums/showthread.php?t=4716 CNC Router Version 1 [====================] 100% http://cnczone.com/forums/showthread.php?t=39294 CNC Router Version 2 [=|-----------------------] 5% |
| Actually no, but that is a fantastic job you did there. Instead of using round stock, you use plates of it, i like that. And you say with some silicone lube it works even better? Why did you not simply bore the hole perfectly to fit the shafting? what i was reffering to was a picture, it was in one of the galleries. This guy used round delrin stock and bored them out |
I cut the reliefs to reduce surface contact area to reduce the friction as well.
| I don't get any play or chatter from the bearings. The only problem I had was getting them aligned so they didnt' bind on the round stock. I'm sure this wouldn't be a problem if I had machined these bearings but I used hand tools when I made them. I should mention that for my next design I will be switching to using skate bearings. There is just too much friction as far as I'm concerned. I know I'm wasting a lot of energy from my steppers just overcoming the friction of these bearings. Although, they DO work.
#10
| I'm still 'playing with the idea' of using Delrin bearings, I'm torn between skate bearings and Delrin, lucky for me there is stacks of spare Delrin Blocks at work that I'm allowed to use, I've got 1 1/2 inch stainless bar for one axis (supported on the underside) and the other is 20mm probably silver steel (I've yet to purchse it) I thought of broaching or maching out about 50% of the bearing surface also. a big kinda problem for me tho is that both designs are 'open bearing' designs ie the bars I have are all supported with a plate on the underside of the bar, but maybe that will allow me to effectively adjust the bore size?? I'm honestly unsure still which way to go. my steppers are on the small side (I expect I'll have to cough up and buy bigger ones tho anyway). Delrin for me is free !! and I don't want swarf/dust in skate bearings? I'd pondered an air feed to the delrin blocks - rather like an air-bearing? umm got no compressor and it may be noisy ! nice n simple mind... maybe I'll go down that route after all? |
#11
http://www.cnczone.com/forums/showpo...1&postcount=53 |
#12
| Actually I think UHMW is slicker. Cheap on ebay, drills and machines nice and easy.
__________________ Phil, Still too many interests, too many projects, and not enough time!!!!!!!! Vist my websites - http://pminmo.com & http://millpcbs.com |
