Go Back   CNCzone.com-The Largest Machinist Community on the net! > Mechanical Engineering > Linear and Rotary Motion
Linear and Rotary Motion Discuss ball/Acme screws, R&P, linear slides and theory here.
Old 12-29-2005, 10:03 PM
tpworks's Avatar
tpworks is on a distinguished road
Question Rotating nut plan/Diagram
Does anyone know where I can locate a diagram or plan for a rotating nut
like the one used here? http://www.stirlingsteele.com/files/leftviewZaxis.jpg
I am converting a mini-mill and I think this is the best option because the screw stays out of the way of flying debris.
Tom.
Old 12-30-2005, 04:11 AM
posix is on a distinguished road
Ermm...yes...are you sure about that? Your screw will be exposed just the same if you think about it carefully, it's only that in your scenario the nut is rotating rather than the screw.
It's only where the lead screw is so long that it becomes heavy and wobbly that you use a rotating nut.
Old 12-30-2005, 11:21 PM
tpworks's Avatar
Yes I'm sure about that. the screw would be attached to the top of the Z axis , not passing through it as seen in this picture. (http://www.stirlingsteele.com/files/leftviewZaxis.jpg)
eerrm, think before you reply.
Old 12-31-2005, 01:08 AM
WayneHill's Avatar
WayneHill is on a distinguished road
Posix,
Jeff Davis sells plans for a rotating nut assembly.
http://www.homecnc.info/cncparts.htm
http://www.homecnc.info/cnc-main.html
If you look close at the pictures on his web site, you get an idea of
how it is setup.
Wayne Hill
www.codemangler.com
Old 12-31-2005, 12:05 PM
AustinT is on a distinguished road
I too have been thinking about this. I wish someone would make a hollow shaft stepper with a built in ballscrew. The motor would crawl up and down the screw and would mount to a linear bearing system to carry the weight. Screw whip would not be an issue. To keep the dirt out I would use 2 pieces of convoluted tubing. For example a 8 foot screw would have two 4 foot pieces of tubing to protect the screw from dirt.
Old 12-31-2005, 01:41 PM
tpworks's Avatar
There is a stepper that does that (linear actuator stepper)http://www.hsimotors.com/linear-actuators/
http://www.anaheimautomation.com/23A34Aactuators.htm
Old 12-31-2005, 01:46 PM
Hi Yes I found that stepper just after my previous post. Why dont we see any of them used here at cnc?
Old 12-31-2005, 01:48 PM
tpworks's Avatar
$$$ cost!
Old 12-31-2005, 09:29 PM
H500 is on a distinguished road
A rotating nut is no harder to design than a static one. Just do it the usual way, except that the diameter is scaled up so that the ball screw will thru inside the rotating piece.
Because of the large diameters, the cost will be considerably higher, so it should only be done when necessary.
Old 01-01-2006, 05:30 PM
tpworks's Avatar
Thanks Wayne Hill
and as for Posix I asked for plans or diagrams not critics if all you have to input is negativity then I suggest that you don't bother posting.
Enough said.
  #11   Ban this user!
Old 01-05-2006, 09:28 AM
As for tpworks I didn't criticise anything just asked whether you really needed the added complexity of making a rotating nut. And if you are a sensitive type I suggest you don't bother reading replies that you consider to be in a vicinity of even remotely seeming like they may contain an offensive thought and go suck on a thumb or something. Jeez...
  #12   Ban this user!
Old 01-14-2006, 10:42 AM
Evodyne's Avatar
Evodyne is on a distinguished road
Exclamation The referee enters the ring!
Guys,
Hi. One of the benefits of the CNCzone site is the free exchange of ideas and experiences. This works best when we are open minded to the replies others offer, and when we are courteous and respectful in generating our own replies.
One of the less-desirable "jobs" of being a moderator is stepping in when things don't go so smoothly. Less desirable but important. Negative exchanges can quickly escalate and get out of control, so I really can't let them go on in my forums. Let the punches and counter-punches stop here and now. I have spoken.
Your friendly neighborhood moderator,
Evodyne
