Go Back   CNCzone.com-The Largest Machinist Community on the net! > Mechanical Engineering > Linear and Rotary Motion
Linear and Rotary Motion Discuss ball/Acme screws, R&P, linear slides and theory here.
Old 12-24-2005, 09:35 PM
AKFALAR is on a distinguished road
longest span for a single bearing for Plasma Y axis
I already used a BWV dual vee setup however it is not stiff enough in torsion. whick affects the y-axis linearity. I would like to add a rod bearing to the gantry. I think it would stifen the frame nicely.
I am concerned on how much span can be had. what diameter should i use?
I am spanning a 6' area supported of course on the ends. Again, there is a supported bearing already but this one in order for it to fit on the existing insatallation must be a free span.
recommendations appreciated,
AKFALAR
Old 12-25-2005, 04:30 AM
Apples's Avatar
Apples is on a distinguished road
My plasma table has a y axis span of 2 meters. I am also using the vee bearings.
I had to have a motor driving from both sides of the table to keep it square and stiff.
Peter
(Australia)
Old 12-25-2005, 07:56 AM
ger21's Avatar
Do you have any pictures. Sound like whatever your DualVees are mounted to isn't stiff enough.
Old 12-28-2005, 01:04 AM
Apples's Avatar
http://www.cnczone.com/forums/showthread.php?t=4900
This is my table.
Peter
Old 12-28-2005, 01:31 AM
ger21's Avatar
Peter
(Australia)
Looking at your pictures, it looks to me like that plate the V's are mounted to isn't attached to the beam nearly secure enough to eliminate racking. The plate itself is/ was probably flexing, too. jmo, though.
Old 12-28-2005, 02:02 AM
Apples's Avatar
It's only held together with f clamps at the moment. I am going to weld it up soon.
There is no flex with the other side being driven.
Peter
