| Linear and Rotary Motion Discuss ball/Acme screws, R&P, linear slides and theory here. |
The thing in red is what i am trying to get off. There are no set screws around it. I have tried spinning the shaft the opposite direction, it won't budge. Has anyone seeen anything like this before? If so, do you know how I could get it off? |
| Looks like a double nut, with a dog setscrew drilled halfway into each. Remove the setscrew(s) completely, then you should be able to loosen off the outer one.
| Looks to me like you'd need a "C" spanner. I think that's what it's called. It's basically a hinged C shaped (part ring) with a pin on one end that locates in one of the holes around the body of that nut. Not sure if that's right, but that's how it looks from here. Regards Terry. |
| It looks to me that there is a threaded dowel, if so you need to use a bolt extractor that threads into the dowel and then draws itself out either by slide hammer or exerting force against the retainer. Car steering wheels use this same idea. Al.
I have copied one of your pictures and drawn a white arrow on it pointing at two semicircles which do not quite line up. This nut assembly is probably something to do with adjusting tension or backlash and you get different amounts of clearance by lining up different semicircle pairs and driving the pin in at that location. |
