Go Back   CNCzone.com-The Largest Machinist Community on the net! > Mechanical Engineering > Linear and Rotary Motion
Linear and Rotary Motion Discuss ball/Acme screws, R&P, linear slides and theory here.
Old 12-21-2005, 05:52 PM
hardyn is on a distinguished road
cheap round rail linear guide stand-offs?
does anybody know of a cheap source for the aluminum extrusions that stand- off the round linear guide rail? products like that from THK and INA are almost as much or more than the rail.
(tee shaped extrusion with holes drill in them for mounting to the rail?)
thanks.
Old 12-21-2005, 06:21 PM
MrBean's Avatar
Gold Member
MrBean is on a distinguished road
I don't know of anywhere cheap that sells the rod support, but have you considered making your own in short sections to support the rod every 6 inches, for example. I can't see why it wouldn't work reasonably well.
Similar to this:
Old 12-21-2005, 06:23 PM
Gold Member
Ken_Shea is on a distinguished road
What did you find the cost to be each, and what size ?
Ken
Old 12-21-2005, 06:25 PM
it was sometime ago when i looked, i will look for my paperwork and get back to you.
Old 12-21-2005, 06:32 PM
DanOSB is on a distinguished road
well i already got those made for my table and i can get more of those made for you if u are interested.. the cost is 8 dollars each.. they are for 1 inch shaft but i can design it for another size if u want..
some sample images of it..
i am putting them every 8 inch apart the shaft support is 2inch long by 1 inch wide by 1 inch high
hope that helps.
ID:	13071   Click image for larger version
ID:	13072   Click image for larger version
ID:	13073   Click image for larger version
ID:	13075   Click image for larger version
Old 12-21-2005, 06:35 PM
danosb,
those look great, yeah i'll private message you about those. im using metric shafting but if you are willing to change the design that would be great.
thanks.
Old 12-21-2005, 06:42 PM
yes im willing if u get more than 20 of them and lets talk via email instead
Dan
Old 12-21-2005, 09:08 PM
unterhaus is on a distinguished road
I think a lot of people buy the full length support and cut it up. I bought some rails like that on ebay. Certainly cuts the cost down by a large percentage.
Old 12-21-2005, 09:09 PM
i did think of this route but it would be lot more work.. full legnth and then cut them up then drill holes for the shaft thats why i got those made..
