Go Back   CNCzone.com-The Largest Machinist Community on the net! > Mechanical Engineering > Linear and Rotary Motion
Linear and Rotary Motion Discuss ball/Acme screws, R&P, linear slides and theory here.
Old 12-02-2005, 03:09 PM
belgrado is on a distinguished road
Question One ballrail for the y- axis is that sufficient
Hello,
Just one question .
I'm designing my gantry router these days .
It wil mainly be used as a wood router for gutar parts .
Cutting speed is not the most important thing for me.
Over the last year I got lots of linear components toghether, so now I only have to put everything in the right place .
I have a starlinear (bosch rexroth ) rail of 1036mm long in the 30 mm size and two carriages ( 1653-794-20 ) .
I was thinking of using only one rail for the y axis on the gantry .(maybe with two carriages in line about 240mm long together).
I planned on screwing the rail on a 100mm square iron tube (thick walled)and use a leadscrew on the top of that tube to move the y axis so there will be a sort of L saped connection between the carriage and the leadscrew nut support.
The specs of this rail and carriage seem quite heavy and strong so I thought it would be ok to use one rail only for putting on a Z axis mechanism (not too heavy )and a 1 1/2 hp router motor .
The Z axis movement will be about 4 inches .
Thanks for reading this post .
Paul Belgrado
Belgium
Old 12-02-2005, 04:02 PM
andy_ck87028 is on a distinguished road
A picture beats a thousand words
If I am right in picturing your plan, I am concerned that the carriages would be subject to excessive turning force caused by the z axis.... but I am not confident I have answered appropriately.
Andy
Old 12-02-2005, 04:49 PM
Andy ,
Thanks for the reply .
Here's a picture of the rail with a porter+cable 690 router so you can see the size .
If the beam where the rail is screwed on is very strong will it work ?
You can check out the specs on the attached documents .(size30)
greetings
Paul
ID:	12483   Click image for larger version
Old 12-02-2005, 11:13 PM
ViperTX is on a distinguished road
For the limited z-axis movement and since you're only machining wood or plastic...it should work....what you want to avoid is creating a canterlever setup where the router is at one end and the support is at the other end...
