Results 1 to 10 of 10
Thread: Drive ratio question
    Jan 2012
    Ok I am building a cnc laser table and im at the x axis setup but am stuck a little. Where Im at is i see guys and there builds go from a small tooth gear to a larger gear back to a smaller gear. This makes no sense to me as it sounds like there going big then back to the start. I am running a nema 23 270oz/in motor 1.8 degree 200 spr and I am looking for ideal speed needed for my cnc laser table. I am running a single motor with dual shafts to each side of my gantry. I will be using a 3/8" wide groove belt running along each side of my table (4x8) mind you. Does anyone have some formulas or good insight on this matter. All information is much appreciated guys.
    Mar 2003
    Shelby Twp, MI....USA
    You should know how fast you want the machine to go, and then choose your components to achieve that speed. That probably depends on what type of laser you'll be using, and what you'll be cutting.
    Jan 2012
    Your right but is there some type of formula that will allow me to get to this number. Lets say i want 1000 ipm.
    Registered lgalla's Avatar
    Jul 2006
    canada
    AmbiguosMind Wellcome to the forums.
    I understand your question but that is not my department.I will transfer you over to our experts.Al-The-Man or Gerry.They can take care of you
    Larry
    L GALILEO THE EPOXY SURFACE PLATE IS FLAT
    Jan 2012
    thank you guys for your quick responses. Much appreciated
    Jul 2006
    canada
    Sorry Ambiguois It is Sunday nite the boys are probably sleepin.Being a wood burner I know little of lasers but the belt reduction you are looking at is probably 3/1.Are you using R&P?
    Jan 2012
    No I am using a linear motion rail from Glacern and the pulley system will be belt driven.
    Jul 2006
    canada
    The problem with belt drive fore the x axis is it is just too fast.You need high reduction 10/1 or more.If you have 1" pulleys 1RPM is 3" travel so 1000-RPM is 3,000IPM.It is costly to use belt drive as you may need gear reducers .Larger pulleys are even faster.Search the forums for belt drive
    Sep 2010
    Quote Originally Posted by AmbiguosMind View Post
    consider using a motor sizing program such as:
    MOTIONEERING® | Kollmorgen
    it may take u an hour figuring it out but it will answer all ur sizing questions in the end and even help pick proper size motors (servo or stepper).
    Mike (at) KilroyWasHere (dot) com -- servo/spindle/vfd motors/drives/controls sales/service/repair/retrofit
    Jul 2006
    canada
    1. Drive ratio question for new build
      By Kentuckyfarmer in forum Plasma, EDM and other similar machine Project Log
      Last Post: 02-14-2011, 08:09 PM
    2. Newbie- belt drive ratio please help
      By drumsticksplint in forum General Waterjet
      Last Post: 09-19-2010, 04:08 PM
    3. Newbie- Drive screw to sepper ratio
      By patternmakerdavev in forum General Metal Working Machines
      Last Post: 08-10-2008, 09:20 AM
    4. Ratio question
      By Splint in forum Mechanical Calculations/Engineering Design
      Last Post: 01-12-2006, 08:19 AM
    5. Timing belt/ratio question
      By kinneycan in forum CNCzone Club House
      Last Post: 09-24-2004, 05:20 AM
