Results 1 to 3 of 3
Thread: What resolution is neccessary for a lathe?
    Jun 2010
    Hi just wondered what resolution was required on a lathe ballscrew IE movement per step.
    Right now I am going for .0004 per step. Will this give me a decent finish in both the X and Y direction. even on a taper?
    Oct 2005
    I would personally like more resolution than that. Consider too that if taking a cut from the radius the diameter of the part will decrease by twice the depth of cut.
    So that would give you 0.4 thou off the radius so becomes 0.8 thou off the diameter. I don't think that is a fine enough resolution for detail work like fitting bearings etc.
    Jun 2010
    Quote Originally Posted by RomanLini View Post
    I was just thinking that yesterday so I am going to get a 2mm pitch screw for the X axis. That will have almost 10 times more resolution, which will mean something along the lines of 5X on Diameter. So closer to a tenth total. Then i can gear that down if need be.
    Thanks for the reply
  1. how much resolution do I need?
    By jrz126 in forum General Electronics Discussion
    Last Post: 01-12-2011, 07:51 PM
  2. Resolution
    By Allan in forum Linear and Rotary Motion
    Last Post: 10-27-2009, 04:38 PM
  3. CNC resolution
    By sinha_nsit in forum Mechanical Calculations/Engineering Design
    Last Post: 10-22-2008, 05:11 AM
  4. Stepper resolution
    By dfwiii in forum Stepper Motors and Drives
    Last Post: 07-18-2006, 08:54 AM
  5. Resolution
    By Laff Riot in forum General Electronics Discussion
    Last Post: 05-29-2003, 03:03 PM
