Results 1 to 3 of 3
Thread: Ball screw bearings, finding preload
    Jan 2007
    I bought new bearings for the ball screws on my mill, SKF 7204 BECBP.
    http://www.skf.com/skf/productcatalo...did=1230020204
    I have read conflicting information on how to install them.
    It appears the best way would be installing them back to back, but I have read the inner rings should be clamped tight and also read the outer rings should be clamped tight when there back to back.
    I am not sure I understand the proload either and can't decipher what it is form the SKF website.
    This is what I think I need to do, find what the preload is (weight) and measure the defection of the outer race when this weight is placed on the bearing.
    Take this measurement X 2 and shim between the races of the two bearings and clamp tight the inner rings and I will have the correct preload.
    Do I have this right.
    How do I find the preload
    Your help is greatly appreciated,
    Bruce
    Mar 2006
    The specified preload is ground into the pair of bearings. When you clamp the inner races together in a back to back (DB) pair, they are preloaded.
    Clamping the outer races to a fixed shoulder in a housing prevents axial motion of the ball screw.
    No shimming is required.
    Dick Z
    ADD: The SKF bearing numbers listed above do not indicate preload or accuracy class. 7204 BECBP indicates a 7200 series 20mm bore, 40 deg. contact angle, paired bearings with a glass fiber cage. Missing are grade such as P4 and preload letter such as A = light preload; B = preload greater than A; C = preload greater than B; CA = small axial internal clearance. This info is from an SKF General Catalog.
    DZASTR
    Jan 2007
    I bought these because they said thery were ABEC 5
    It also says on the bearing 0770 and explorer, I found this on the SKF website.
    SKF Explorer angular contact ball bearings are manufactured only as bearings for universal matching with P6 dimensional accuracy and P5 running accuracy.
  1. Ball screw bearings refilling DIY
    By rbs in forum DIY CNC Router Table Machines
    Last Post: 08-02-2011, 11:03 AM
  2. Need Help!- Rockford Ball screw preload ajustment
    By LUCKY13 in forum Benchtop Machines
    Last Post: 06-16-2009, 09:34 PM
  3. Need Help!- Bmc ball screw support bearings
    By JWC in forum HURCO
    Last Post: 09-27-2008, 10:56 AM
  4. Ball screw without bearings?
    By Halfnutz in forum General Metalwork Discussion
    Last Post: 06-13-2005, 04:10 PM
  5. strange bearing preload threads on ball screw
    By mxpro32 in forum Mechanical Calculations/Engineering Design
    Last Post: 03-10-2005, 09:07 PM
