Go Back   CNCzone.com-The Largest Machinist Community on the net! > Mechanical Engineering > Linear and Rotary Motion
Linear and Rotary Motion Discuss ball/Acme screws, R&P, linear slides and theory here.
Old 10-08-2005, 04:14 PM
GregMM is on a distinguished road
new ACME rod bearing nut idea (maybe)
Im planning on using acme threaded rod in my cnc machine design and was trying to think of a way to reduce the friction and improve the efficiency of the nuts and came up with this (sorry my 3d skills are not good so all I have is a 2d drawing) The green is the block would consist of 3 or 4 around the threaded rod and each side would have to be offset but the thread pitch amount, the blue is normal skate bearings and the red is the bolt that holds the bearing into the block, might be kind of hard to make, was alto thinking if you had a thick pipe can tapered the edges at 45 degrees you could tap that to hold the bearings, but the ends of the pipe would have to follow the thread, instead of just being flat so that would make it much harder to make, but it seems like it would be much more efficient, and should last a lot longer then the nylon nuts
Old 10-08-2005, 05:30 PM
Have a look at the thread here; A different (better) kind of screw
Your idea is similar.
Old 10-08-2005, 06:58 PM
greybeard's Avatar
greybeard is on a distinguished road
I assume you have the acme thread, and the loads on the assembly are not so great that 'wear' occurs rapidly.
If this is the case, would a way of trying out your idea be to rig up the bearings with their bolts in the correct positons round the screw, then cast epoxy onto it.
This way you would avoid the complications of the machining, but it would give you something to test the idea.
