Results 1 to 2 of 2
Thread: Curious About Driven Nuts
    Jan 2004
    NEW HAMPSHIRE
    L.O.L. I think I made a funny. Seriously what are the advantages of a driven nut? I toyed with ideas of just putting a nut into the center of a pulley and adding a cutout to the center of another and there I would have it. Can one save space with it or gain stability in the lead screw? Just curious.
    Registered Torsten's Avatar
    Nov 2004
    U.S.A.
    Sometimes it may be adventatious in a Design solution.
    The main reason for using a Driven Nut Design is to eliminate Screw wipping wich can happen when a Screw is driven at high RPM's.
    The longer the unsupported length of a Screw the lower the Rpm has to be to prevent this.
    The larger the Diameter of the Screw the more it will be able to resist wipping.
    A Driven Nut eliminates this problem because the Screw will be Stationary so
    no wipping can occure.
    Back to the humorus side: A lot of people have been driven Nuts by there wipping Screws.
  1. direct driven or belt driven
    By jeremy0203 in forum Benchtop Machines
    Last Post: 07-27-2011, 12:23 AM
  2. leadscrew nuts and half nuts
    By jayhawkman in forum EBAY ADS
    Last Post: 11-07-2009, 02:00 AM
  3. Just Curious
    By rodneydeeeee in forum Polls
    Last Post: 04-20-2009, 04:13 PM
  4. curious....
    By pulsar110 in forum General Laser Engraving & Cutting Machine Discussion
    Last Post: 10-29-2007, 06:33 PM
