I was able to buy cheap, several lengths of THK HSR-25 rails.
I'm trying to figure out which bearing blocks will fit these rails.
THK website was very confusing. I found some SHS-25 bearing blocks on E-bay, but cannot find any info if they will fit or not.
Any help would be appreciated. Thanks.
HSR 25 R or A wud be the perfect choice!
In theory, the SHS and HSR rail profiles are common between them. Louie's experience is a little worrying in that respect. If you really want to take a flyer, I read a PowerPoint presentation from ABBA that seemed to indicate that they were compatible with THK, as well. I'd need to find the gear very cheap to start going across manufacturers, though.
I have both HSR25 and SHS25 and the rails are not the same. The blocks are not interchangable.
