| Linear and Rotary Motion Discuss ball/Acme screws, R&P, linear slides and theory here. |
| Do I have to use timing belts or gear box? I have 3 ballscrews for the 3 axes. (X-Y-Z) Screw Dia.--- Screw Lead --- Long--- Starts 5/8 in ----------- 13/64 -------- 42in ------ 1 1 in --------- 1/4 --------- 48in ------ 1 12mm --------- 2mm ----------- 30mm ------- 1 I being reading Mach 3 user guide, it helps, but, Do I need to use some kind of reduction gearing "gear box or timing belts and pulleys belts". Or I can connect direct to the steps motor to the screws The step motors are 300 oz/in with 10us steps. I'm just want to use for wood milling or router. I will prefer to use in mm units. When I calculated the mach3 steps per unit, using inches units one of the ballscrews gave me 25400 ( I think they are pulses). Soo.. Do I need to increases the frequenzy to 35000Hz? I know if I use gear box I will increase the torque but lose speed. How much torque do I need to milling wood in 3D? Last edited by Chivo; 09-28-2005 at 03:16 PM. |
| I dont think you need a timing belt with 300oz motors. Unless you have one large machine, i would not bother. Getting a timing belt on there will increase resolution, and i believe torque. But like you said, how much torque do you need for milling wood in 3d? |
| finding a gearbox that has no backlash will be tough; not to say expensive too Timing belts are easy to set-up and very stronge; i have never had a problem with mine on my Z axis for the lathe; runs just about every day |
| That is true, i notice many who put a timing belt on their Z axis of milling machines. I have got two stepper motors sitting around with a pulley already attached to the shaft, i guess i will use a timing belt for when i convert my lathe |
| What about the connection between the screw and step motor. I should use belts or direct shaft coupling. I found some belts from W.M: BERG (http://www.wmberg.com/index.htm) and they have 0 backlash |
| Use these: http://www.ruland.com/flexes.html
