Go Back   CNCzone.com-The Largest Machinist Community on the net! > Mechanical Engineering > Linear and Rotary Motion
Linear and Rotary Motion Discuss ball/Acme screws, R&P, linear slides and theory here.
  #13
Old 11-21-2005, 05:15 AM
*Registered User*
Bluesman is on a distinguished road
Originally Posted by phantomcow2
maybe I will try it for my Z axis. Ive got some nice duplex bearings i need to use up, its a good excuse to machine some bearing blocks. The website says it has .004"/ft accuracy. Considering my Z is probably half of that, I can live with that figure.
But Remember the .004 is the lead accuracy, You still have a bout the same amount in backlash. But for a gravity axis that may not matter. As long as you know the spec,s then if it is all you require, Then I would say you are all set.
I am acually looking at the same assembly for a project that I am working on. But all I got to do is lift
Bluesman
  #14   Ban this user!
Old 11-21-2005, 05:27 AM
phantomcow2 is on a distinguished road
Yea i see they say .001-.004 for backlash. As long as backlash is consistent i don't care. Thats what is making me want to look at ballscrews. My current setup allows for no adjustement in the Z axis for backlash, and it wears and backlash increases, its definantly at more than .004 now. My hopes are that a ballscrew will be consistent, i dont expect it to retard wear, but i do expect if it has .003 or whatever, it stays that way for much longer than a 60 deg thread.
The rest is all software comp
  #15   Ban this user!
Old 11-25-2005, 09:42 PM
H500 is on a distinguished road
I haven't measured it, but the assembly I got from mcmaster seem to have about .01 backlash. Its very loose. I intend to use 2 ballnuts to get rid of it.
