Ah, here's something I just ran into:
So, reading similar stuff convinced me to consider this whole belt drive thing in the first place. Of course even with the belts for scratch, it looks as if getting the rest of the parts might be expensive...
I'm thinking of using them with two same size sprockets, run along the y axis gantry beam. Total span might approach 70". I thought that that span might be excessive for having the sprockets oriented with their axes vertical, but I'm second guessing my first thoughts. The total weight of the belts is only just over a pound, and since there will likely be several hundred lbs of tension on the belt, mass would be a negligible component of the bigger equation, I'm guessing. Shaft alignment is probably far more important.
So, if anyone has any experience with belt drives, I'm now considering other factors that might limit the span. Particularly, whether belt 'whip' or 'flap' or whatever from running at high speeds would be an issue.
