Page 1 of 2 12 LastLast
Results 1 to 12 of 16
Thread: Linear guides
    Jul 2010
    Colombia
    Linear guides
    Good morning,
    This is my first post. I'm designing a machine tool and I want to know all about linear guides. What kind of linear guides exist? I wish someone could help me.
    Thanks.
    Apr 2010
    Start here:
    LM Guide [ THK || USA ]
    And here:
    Ball Spline [ THK || USA ]
    Lots of reading ahead of you, unless you have specific questions.
    Jul 2010
    Colombia
    Thank you very much. I want to achieve a high resolution. Should I use air linear guides?
    Sep 2010
    Here is another link for you.
    I am using their modular V rails bolted to 8020 extrusions. They are very smooth and precise.
    Linear Bearings, Linear Actuators, Linear Guides, Roller Bearings, Linear Motion Solutions
    Jul 2010
    Colombia
    Thank you.
    Apr 2010
    Quote Originally Posted by Imaginebreaker View Post
    Pneumatic solutions are low cost and can be very high speed. Variable accuracy is not their strong suit compared to purely mechanical solutions (air acts as a spring which necessarily has variable amplitude).
    You may also want to look into a kit. This will take a lot of the design out of your hands so you can focus on assembly. Designing a moderately high precision CNC router can be a challenge, but actually assembling one that lives up to the design is an even bigger challenge, IMHO.
    Mar 2006
    Imaginebreaker, You said "machine tool", what are you wanting to build? Mill, lathe, drilling machine or a router? Actually, it depends on what you want to machine, what will the product be?
    Dick Z
    DZASTR
    Jul 2010
    Colombia
    It's a mill. Its purpose is make microcomponents or at least components with one of its dimentions in micrometers.
    Apr 2010
    Sounds like you don't need a big format machine, then. If true, then definitely look into the linear guides, rather a ball spline. At small dimensions, the cost of the rail on eBay isn't too bad. The real trick is getting enough rail so that you have room to have two carriages per rail with enough room for them to move. If you go digging on the THK site I linked, above, you will find information on how to mount the rails, which is the real challenge.
    After that, you will want to look into ball screws with sufficient accuracy for your parts. Fortunately, you can get C3 ball screws for not a lot of money on eBay, but the question is whether even that will be sufficiently accurate for what you want to make.
    Jul 2010
    Colombia
    This is the first prototype, so I guess I can achieve a good accuracy if I follow your recommendation. Thank you.
    Mar 2006
    You want to work in microns? How many microns (.000039")? That's fine grinding and lapping territory. Pretty difficult on a DIY mill.
    Dick Z
    DZASTR
    Jul 2010
    Colombia
    I'd feel satisfied if I can get 100 microns dimentions.
  • Page 1 of 2 12 LastLast
    1. where to buy linear guides
      By MBG in forum General Waterjet
      Last Post: 06-06-2012, 09:56 PM
    2. Replies: 1
      Last Post: 05-04-2011, 12:16 PM
    3. Just IN- PBC Linear Offers New Profile Rail Linear Guides
      By Pacific Bearing in forum Product and Manufacturer Announcements
      Last Post: 04-30-2009, 04:53 PM
    4. Linear Guides
      By rgillard in forum Linear and Rotary Motion
      Last Post: 01-18-2008, 12:16 PM
    5. Linear guides
      By canadamaxxer in forum General Waterjet
      Last Post: 11-30-2006, 01:32 PM
