Results 1 to 3 of 3
Thread: modifying hiwin rail
    Apr 2011
    i got a deal on some never used "t" style rail but i really need an "r" style rail. has anyone had luck machining the "t" rail to mount like "r" rail?
    "t" style rail
    "r" style rail
    thanks
    Apr 2010
    I looked into the issue of just cutting one of the rails that I have (THK SR30), and the issues of heat build-up and damage to the rail scared me off. Unless you had an especially short axis, I would consider a lot of alternatives (e.g., re-designing to use the under mount, sell of the existing and look for what you really need) before signing up to drill a bunch of holes in what should essentially be case hardened tool steel.
    Sep 2006
    Hi, this looks like mounting holes for cap screws etc.
    Only way, without damaging the steel which is case hardened tool steel, is to get it spark eroded...pretty simple job as it's only a straight through hole with a counterbore.
    You "might" be able to drill it with a diamond inpregnated drill, but this is more like wearing it through, and could take hours.
    Ian.
  1. Hiwin Linear Bearing/Rail SALE
    By kwms1956 in forum Linear and Rotary Motion
    Last Post: 08-31-2010, 03:17 PM
  2. need hiwin linear rail cad files awg15 awg20 series
    By eloid in forum DIY CNC Router Table Machines
    Last Post: 08-12-2010, 06:34 PM
  3. HIWIN LG25 Linear Rail
    By Smiler in forum Want To Buy...Need help!
    Last Post: 03-13-2009, 07:27 PM
  4. need hiwin cad files for old ag series rail and blocks
    Last Post: 03-10-2008, 09:36 PM
  5. New models of Hiwin linear bearings/rail
    By kwms1956 in forum Product and Manufacturer Announcements
    Last Post: 06-22-2007, 04:56 PM
