Originally Posted by
RICHARD ZASTROW
I think the bearing engineer you refer to is NC Cams. Unfortunately, our good friend has passed away. MHRIP
I've been reading your posts. I may have forgotten the part on C3, C5 & C7 on angular contact bearings but I think that refers to ball-screw accuracy. It could also refer to internal clearance of radial ball bearings like deep groove ball bearings.
Angular contact ball bearing accuracy grades here in the USA are ABEC 1, 3, 5, 7, & 9.
ABEC1 being the lowest, ABEC9 about as high as they get generally. The higher the number, the higher the accuracy.
When mounted face to face, AC bearings are a little more forgiving as to alignment. Mounted back to back, they are more rigid.
Ball screw support bearings are mostly axial (thrust) bearings, usually 60 degree contact angle. In lower force applications, a lesser angle is probably OK. Check the bearing specs to be sure.
The ball screw support bearings are usually made with fairly high preload so they do not like sustained high speed.
Lots of information about bearings out there. Read the tech sections of the bearing catalogs, good stuff.
Too bad we don't have Dennis anymore.
Dick Z
