Results 1 to 2 of 2
Thread: Timing belt material
    Dec 2009
    I need to replace some long 1/2" wide L series belting that drives the long axis on my plasma table. I'm finding it in Urethane with steel cords which I have now, Urethane with Kevlar cords or Neoprene with fiberglass cords.
    I'm mainly concerned with it not stretching. Does anybody have the low down on which would be best for this application?
    Thanks for any input.
    www.modernironworks.com
    Mar 2006
    Gates makes GT2 carbon fiber belts. You'd have to do a little investigating to determine if it meets you needs. Might be a bit more expensive than the others though. After initial installation they're not supposed to stretch.
    Dick Z
    DZASTR
  1. HTD Timing belt and backlash
    By BWay in forum Linear and Rotary Motion
    Last Post: 12-20-2010, 01:17 PM
  2. Need Help!- No timing belt available for lathe
    By rusel in forum General Metal Working Machines
    Last Post: 12-11-2010, 08:33 PM
  3. Timing belt reduction, which to use?
    By phantomcow2 in forum Mechanical Calculations/Engineering Design
    Last Post: 12-30-2005, 12:19 AM
  4. timing belt reduction
    By drwc in forum Benchtop Machines
    Last Post: 05-23-2005, 04:31 PM
  5. Should you put grease on a timing belt?
    By ynneb in forum DIY CNC Router Table Machines
    Last Post: 04-22-2004, 09:54 AM
