Results 1 to 11 of 11
Thread: Coupler Recomendation and Sourcing
    Registered Connor9220's Avatar
    Aug 2010
    I just snapped another cheap Chinese Helix coupler today. 2nd one. I'm looking for replacements now. I don't want to break the bank either. I'm using 354oz-in Steppers. Bore size for stepper is 8mm, for the ballscrew it's 10mm. O.D. should be under 1" and length around 30mm can be a little longer. I'm looking at this one from SDP-SI. https://sdp-si.com/eStore/PartDetail...9&GroupID=1060 It looks like it might work The length is a bit longer than the old one. But, it's made out of Engineered Polymer?? I.E Plastic!! Anyone tried these? It's rated for 3.8 N.m which is enough torque.. Not sure how much backlash or anything.. But, at $16.76 each.. looks like it might be worth a try? Anyone else have a good source?
    Thanks, Connor
    Inner Vision Development Corp. - http://www.ivdc.com
    Website Design & Development. Shopping Carts, SEO and more!
    Dec 2003
    Misumi have a good selection, most are metric but they do have a range in Imperial.
    Aug 2010
    Quote Originally Posted by Al_The_Man View Post
    Metric is good.. Who's a dealer for them? Doesn't look like I can get direct from them.
    Registered lgalla's Avatar
    Jul 2006
    canada
    As far as I know you can buy direct.Just register
    Larry
    L GALILEO THE EPOXY SURFACE PLATE IS FLAT
    Aug 2010
    I got lost on their website..
    Okay.. so, Odham's look good, but, is the pricing per hub, or complete unit ? Will those work if the motor isn't 100% parallel to the shaft? I know they can be offset.. They should be parallel.. but.. I drilled the holes by hand.. so, who only knows how accurate I was.
    Thanks, Connor
    Dec 2003
    Quote Originally Posted by Connor9220 View Post
    Misumi deal direct, I order from Misumi US all the time.
    Aug 2010
    Yea, I figured it out.. Got a little lost on their site.. it's rather large!
    Anyway... Oldham vs Flex? the Oldham's look cheaper, but, can't tell if that's for the complete coupler, or just 1/2.. Also, what if my shaft is off just a tad (parallel wise vs offset).
    Thanks, Connor.
  8. #8
    Dec 2003
    Don't buy aluminum helical for steppers or servo's, if you must use helical, go the extra cost and use stainless, Oldham are good also.
    The price is for a complete coupler.
    Aug 2010
    Steppers are 354Oz-in, I've already found out the hard way about aluminum vs stainless.. Anyway, How much miss-alignment (not offset) can Oldham's handle if any? How about backlash? also, re helical the same as Beam ?
    Thanks, Connor
  10. #10
    Dec 2003
    If you have mis-alignment I would suggest a disc coupler of some kind, Lovejoy make a version, absolute zero backlash.
    These are among the best types but are usually costlier.
    Jul 2006
    canada
    Sorry to be off topic.Where is the buy Al's beer thread?
  1. Sourcing LMD18245T
    By Drools in forum General Electronics Discussion
    Last Post: 09-18-2010, 01:59 PM
  2. VFD recomendation
    By Danno in forum Phase Converters and VFD
    Last Post: 11-17-2008, 12:07 PM
  3. CPR PPR recomendation
    By wcarrothers in forum DIY CNC Router Table Machines
    Last Post: 08-31-2006, 04:04 PM
  4. I need some help sourcing some equipment
    By eitanwaks in forum Linear and Rotary Motion
    Last Post: 05-20-2006, 05:59 PM
  5. EDM Recomendation
    By Tim J in forum CNCzone Club House
    Last Post: 10-26-2004, 07:16 PM
