Hi
Refering to the attachment, u can find a assembly in which 2 axial bearings are fixed.
I was wandering that how the fitment of these axial bearings would be done.
I am concerned that how I should fit the bearings so that the PLYWOOD Movement would be balanced one. Balanced means the factors like end play, clearence, friction are consistent on both sides so that the plywood would oscillate properly when forces come from radial & axial directions.
Is there any SPM to do such balancing?
Ash
