Go Back   CNCzone.com-The Largest Machinist Community on the net! > Mechanical Engineering > Linear and Rotary Motion
Linear and Rotary Motion Discuss ball/Acme screws, R&P, linear slides and theory here.
Old 07-11-2005, 05:46 PM
DieGuy's Avatar
DieGuy is on a distinguished road
Using threaded rod for drive screws
From another thread I started looking at the MSC catalog online. I wondered if anyone has used alloy steel oil finished or chrome moly zinc plated 3/4-10 rod to drive there machine. I would think that it would help the whipping problem at higher RPM and smooth the acceleration by adding some mass to get spinning while providing a longer pitch for speed.
http://www1.mscdirect.com/CGI/NNSRIT...5705&PMCTLG=00
Old 07-11-2005, 09:50 PM
ger21's Avatar
You'll need much bigger motors if you use 3/4" screws vs 1/2" screws. The extra mass is much harder to spin.
Direct Drive Vs Belt Drive for a Mill/Drill Retrofit? pfeist General Metal Working Machines 10 03-01-2008 05:02 AM
Ball screws, Acme screws, threaded rod DJ Morrow DIY-CNC Router Table Machines 11 03-22-2007 01:39 PM
Question obout acme threaded rod (lead screws) Hack Mechanical Calculations/Engineering Design 1 04-02-2005 01:12 PM
Acme threaded rod use Apples DIY-CNC Router Table Machines 6 05-12-2004 01:54 AM
