Go Back   CNCzone.com-The Largest Machinist Community on the net! > Mechanical Engineering > Linear and Rotary Motion
Linear and Rotary Motion Discuss ball/Acme screws, R&P, linear slides and theory here.
Old 07-11-2005, 09:36 AM
Chunky is on a distinguished road
Amazing (to me) if true
I did do a search before posting. Couldn't find any threads on it. If this is for real, and if the thrust is adequate, I'm probably a player. If I understand correctly this thing uses a plain shaft for a lead screw. The only one that SmallParts.com stocks is the 3/8" but that's enough for my project. I have no idea what kind of thrust I need. Can you guys check it out and let me know what you think. (I realize it's designed to slip)
Old 07-11-2005, 09:43 AM
ger21's Avatar
You'll need more than 15lbs of thrust. Probably 50-100lbs minimum, for what you want to do. You need a lot of thrust to accelerate quickly to the speeds you want. Sorry, but I don't know the formulas to determine the needed thrust.
Old 07-11-2005, 10:18 AM
ger21]You'll need more than 15lbs of thrust. Probably 50-100lbs minimum, for what you want to do. You need a lot of thrust to accelerate quickly to the speeds you want. Sorry, but I don't know the formulas to determine the needed thrust.
That's okay. You told me what I needed to know. AFter I posted I got to thinking it would probably be difficult to compute how many inches per revolution and such as that. Cool concept though. Maybe later.
Old 07-11-2005, 10:27 AM
Just realized I never did post the pic.
Old 07-11-2005, 12:08 PM
buscht's Avatar
buscht is on a distinguished road
Chunky, here's a thread on that topic.
Threadless Ball Screw
Old 07-11-2005, 02:13 PM
OCNC is on a distinguished road
I happened to notice a couple of days ago while in the supermarket that this type of 'screw' is used as the mechanism that moves the automatic sliding entrance/exit doors. It's located in the head jamb. One of the doors was being serviced and the access cover had been removed. Perhaps someone in the commercial door repair business would have leads for locating surplus units.
Old 07-11-2005, 02:36 PM
mxtras's Avatar
Silver Member
mxtras is on a distinguished road
I have seen similar units in work on a large CMM (Coordinate Measuring Machine) that rode on flat air bearings - it worked in that application for slow speed, high precision moves. I don't think it would be applicable to a cutting machine - maybe a plasma or laser, but nothing with erratic, opposing forces to the drive system.
Scott
Consistency is a good thing....unless you're consistently an idiot.
Making the HF mill run true and smooth CNCadmin Benchtop Machines 2 10-04-2004 04:33 PM
Encrypted cutting code in this picture ( Amazing) ynneb CNCzone Club House 4 06-18-2004 05:26 AM
O/T Amazing video.. Rekd CNCzone Club House 8 01-15-2004 09:36 AM
Too Good To Be True? boss1 OneCNC 14 08-01-2003 01:55 AM
