Results 1 to 2 of 2
Thread: NB Linear System ??
    Nov 2010
    NB Linear System ??
    Does anyone know or have any experience with this type of linear motion?
    NB Linear Systems:TWA8UU 1/2" inch Ball Bushing:Block:Ball Bearings:VXB
    Dec 2009
    Yes, I just finished my build using them, and they are awesome. No friction, smooth as silk. I had build a Solsylva CNC from the plans 3ft-4ft and used the roller skate bearings for the linear movement. It worked, but I had these linear bearing from another build so I kinda redesigned the gantry for the new build. I would use them again. I did a lot of research here on different tables and designs. I like Joe's CNC machines as well and think it would be a good build. I used the v-bearing on the y and z. I have 5 inches of travel on my z which is more than enough to cut the material, plus change out the bit. Hope this helps
    Attached Thumbnails Attached Thumbnails NB Linear System ??-hpim0478.jpg   NB Linear System ??-hpim0484.jpg   NB Linear System ??-hpim0475.jpg   NB Linear System ??-hpim0477.jpg
  1. linear rail system?
    By justin22885 in forum Joes CNC Model 2006
    Last Post: 02-24-2009, 09:54 AM
  2. Interesting Linear Drive System
    By TravisR100 in forum DIY CNC Router Table Machines
    Last Post: 01-17-2007, 12:01 PM
  3. 8 Foot linear guide system?
    By jkpugh in forum Linear and Rotary Motion
    Last Post: 12-10-2006, 07:38 PM
  4. new linear drive system
    By rceebuilder in forum Open Source CNC Machine Designs
    Last Post: 08-21-2006, 01:22 PM
