Go Back   CNCzone.com-The Largest Machinist Community on the net! > Mechanical Engineering > Linear and Rotary Motion
Linear and Rotary Motion Discuss ball/Acme screws, R&P, linear slides and theory here.
Old 07-06-2005, 08:25 AM
Chunky is on a distinguished road
Guide versus Bush (footprint)
Please see my pics below and help me understand the footprint issue. Thanks
Name:	Guide versus Bush.JPG‎
Old 07-06-2005, 09:05 AM
ger21's Avatar
First of all, they'll be a lot closer in size to each other than your picture would indicate. Second, the linear guides are almost always bolted to a steel or aluminum plate, with bolts every 4-6 inches. Third, linear guides carrying loads in any direction other than along down (in your pic) should be used in pairs, which would eliminate the twisting you're worried about. Fourth, the linear guides can carry much higher loads because the balls ride in a ground race, as opposed to riding on a round shaft with an infinately small contact point.
Old 07-06-2005, 10:08 AM
ger21: First of all, they'll be a lot closer in size to each other than your picture would indicate.
That's precisely what I thought until I read the notations. The guide is rated at a dynamic load of 9.51kN while the bush, the giant to its right, is rated at mere 7.35kN. ??? Presumably they're comparing oranges to oranges.
I considered the "pairs" configuration. But then-- you're no longer examining the initial question. Two contact points compared to one has exponential advantage. But if you're going to claim equality "as is" well....
Old 07-06-2005, 10:47 AM
ger21's Avatar
The little guides WILL carry more weight then the large bush type will. Say the small guide is 1/2" (12mm), that would make the round shaft about 2". You're not going to use 2" shaft, is what I'm saying. For a hobby machine, either type 3/4" or bigger will usually suffice. I have some 15mm guides. I wouldn't use anything smaller. Most people go for 25mm or so. The 25mm ones come in longer lengths, and I suspect that most people just can't believe the 15mm ones can carry the loads they are rated at. Our machine at work has a cantileverd 1000 lb head riding on 25mm guides. It hangs about 4 ft beyond the rails!
They both should be used in pairs for any type of machine tool application.
Old 07-06-2005, 12:13 PM
That is beyond belief!
Igus versus skate bearing carlnpa Mechanical Calculations/Engineering Design 3 07-06-2005 12:48 PM
Belts versus Direct Drive bsmith DIY-CNC Router Table Machines 12 06-06-2004 11:09 PM
thk versus thompson newguy DIY-CNC Router Table Machines 5 04-19-2004 01:45 PM
bipolar series versus parallel wiring deft General Electronics Discussion 5 04-01-2004 11:17 PM
mach2 versus EMC georgebarr Mach Software (ArtSoft software) 3 02-22-2004 12:32 PM
