Results 1 to 4 of 4
Thread: cnc stepper motor force - please help
    Oct 2010
    Romania
    hi there everyone!
    i am building an cnc for hobby. i've made the controller board for usb, and one driver for stepper motor. tested them with an old fax stepper engine, and they work, but the problem is the motor force. i can easily stop it with my hand.
    so i am planing to buy some new powerful motors, but i don't know what to choose.
    i never faced the situation to measure the motor force in Nm... so i don't know anything about this
    i saw some motors from nema, with holding toque of 1,8NM up to 12Nm, but how powerful is a motor that has a torque of 1Nm ? this is my main question...
    the cnc machine will have 4 axles: x,y,z and a, for each axle i need a motor that is powerful enough to carry around 5-6 kg... what motor to choose in this case?
    each axle has linear ball bearing for slide back/forward, and the engine shaft will be connected to an ordinary screw of 120cm.
    i hope you guys can help me understand something from this.
    thank you very much!
    Aug 2008
    South Africa
    You can use this page to convert nm to oz.in if that makes more sense to you. I would go for at least 250 oz.in motors.... that also depend on the speed and material you cut.... read read read.
    Jan 2011
    India
    hi tataee1990
    i am also facing the same problem regarding selsection of motor.anybody help me regarding this
    Sep 2010
    download this free motor sizing program called Motioneering and enter your weights etc and it will calculate for you what size motor you need in any units including nm you want!
    http://kollmorgen.com/website/com/en...tioneering.php
  1. Need Help!- 6 leads stepper motor connect to TB6560AHQ stepper driver board
    By wf1318 in forum Stepper Motors and Drives
    Last Post: 07-25-2010, 03:19 AM
  2. Integrated stepper motor? with built-in stepper motor driver
    By uirobot in forum Product and Manufacturer Announcements
    Last Post: 06-07-2010, 04:59 AM
  3. Convert motor torque into linear force:
    By eloid in forum DIY CNC Router Table Machines
    Last Post: 10-17-2007, 10:33 PM
  4. Beltdrive-stepper motor-stepper motor driver
    By Georg in forum Stepper Motors and Drives
    Last Post: 10-16-2007, 05:56 PM
  5. Cam- gear motor - force applied to follower?
    By Chris D in forum Mechanical Calculations/Engineering Design
    Last Post: 05-05-2006, 12:41 PM
