Go Back   CNCzone.com-The Largest Machinist Community on the net! > Mechanical Engineering > Linear and Rotary Motion
Linear and Rotary Motion Discuss ball/Acme screws, R&P, linear slides and theory here.
Old 07-08-2003, 01:05 AM
jakk100 is on a distinguished road
Linear Bearing mat’l?
What type of linear bearing do you use?
(The kind that is used with a continuously supported round shaft.)
Ball bearing?
Frelon?
Ceramic coated?
Cheap sources?
Your thoughts are surely appreciated.
Jakk
Faster is better...
Old 07-09-2003, 10:23 AM
resotek is on a distinguished road
I hope someone will take the time to respond to Jakk. From the pictures I've seen on here it seems like roller blade bearings are popular on X and Y. What about Z? I can't tell what folks are using in this regard.
Cheers,
Mel
Old 07-09-2003, 10:42 AM
CNCadmin's Avatar
Site Owner
CNCadmin has disabled reputation
I'd use any high quailty SS Ball bearing. The Z i'd use a linear slide.
Thank You,
Paul G
Site Owner-Webmaster-
Administrator
www.rfqwork.com
www.cnczone.com
www.welderzone.com
Old 07-09-2003, 10:09 PM
The kind of bearing I would like advise on is for continuously supported precision shaft.
My choice is a linear bearing using ball bearings-see photo.
Product literature suggests the frelon linear bearings offer more vibration damping (good) but higher coefficient of friction (.125-.200), and may mask alignment issues….may wear faster???
The linear ball bearings offer lower .002-.004 coefficient of friction (good), but I am concerned they may vibrate on the shaft.??? Or am I all wet. The cost is comparable from what I’ve seen.
So with that said… I think the linear ball bearing would be the way to go.
What are your thoughts and experiences?
Frelon or ball bearing?
Jakk
Faster is better...
Old 07-09-2003, 10:29 PM
HuFlungDung's Avatar
Moderator
Hi Jak100
(hey, there's a pun there ;0 )
You'd want to be using fully hardened shaft in those linear ball bearings, if that is a consideration. All those tiny points of ball contact do not actually amount to a "good bearing" at all, even though the friction may be low, and providing you have such an exacting fit that they are practically preloaded.
Plastic is a bit draggy as you pointed out.
I'd use Oilite bushings, running on Chrome plated shafting, although it may be a trick to fasten the bushings into an opensided housing. However, working through the open side of the bearing housing, I think a guy could countersink a flathead screw into the bushing to retain it from the inside.
I would also maximize the length (through design) between bearings running on any one rail to minimize slew and jamming.
Old 07-09-2003, 11:58 PM
balsaman's Avatar
balsaman is on a distinguished road
I am thinking the ball bearings would be fine on regular shafting (3/4" cold rolled even?). Yes the balls don't make a ton of contact with the shaft, but there are lots of them, and the pressure isn't that high on a home made machine. It would last many years IMHO. Even with low friction the bearing will be quite tight, ie. no play at all. remember the balls just need to roll along. They actually roll thru the bearing and out the back into a tunnel built in to bring it back around to the front. They work slick (punn intended).
I would stay away from the plastic bearings.
Eric
I wish it wouldn't crash.
Old 07-10-2003, 11:39 AM
Moderator
Cold rolled shafting is pretty soft.
I'm not sure how you would calculate the area of contact of balls with a shaft, but no matter how many you have, the area of contact is still near zero. This automatically creates high pressure contact and the hard balls will very quickly roll a groove into the soft material. This creates unwanted play.
A true raceway needs to be contoured to fit the ball.
I'd be interested to know if these linear bearings are packed with an undersize ball every other ball. This would improve ball flow and reduce skidding of one ball locking against the other because of simultaneous contact with the inner and outer raceway and the ball in front of it.
Old 07-10-2003, 04:43 PM
balsaman's Avatar
Good point about the contact area being close to zero. I don't think the balls differ in size. On my linear bearings, (which are the blocks that run on the squarish rails) the balls are all the same size.
Eric
Old 07-11-2003, 04:38 PM
Zephrant is on a distinguished road
Hu- Many of the raceways now have plastic carriers that isolate the balls from each other, eliminating the need for over/under sizing of every other ball.
(Or so their literature says...)
Zeph
Old 07-11-2003, 05:12 PM
Moderator
Oh, thanks, Zeph, that should be good for the bearing performance.
  #11   Ban this user!
Old 05-01-2005, 05:51 PM
DieGuy's Avatar
DieGuy is on a distinguished road
Are these claims true? Seems Frelon is a good bearing material.
An expanded series of 148 Frelon lined linear bearings from Quality Bearings & Components can tolerate upto 1,500 psi over the portion of the bearing that is carrying the load. These Frelon lined anodized aluminium bearings carry 4 to 8 times the load of ball bearings. A 1/2" I.D. Frelon bearing will carry as much load as a 1" I.D. ball bearing. Long service life for these self-lubricated bearings is another major benefit. Although wear rates are affected by surface finish, shaft hardness. length of travel, contamination and lubrication, these bearings last on average 4 to 8 times longer than ball bearings.
http://www.qbcbearings.com/New/Frelon.htm
Old 05-06-2005, 04:30 PM
mxtras's Avatar
Silver Member
mxtras is on a distinguished road
I now prefer to use mainly linear bearings such as THK HRS series. The cost might be a bit higher than other methods but you get what you pay for.
I recently completed a 1350 pound, 63" wide motion system capable of positioning accuracies of less than 1 micron (0.00004", 0.001MM) - for this application, medium preload THK bearings were used to eliminate stick-slip.
I have also used Turcite (sheet material, bonded) for high loads with mixed results.
Moglice (specialized, low shrink epoxy) is an absolutely awesome method, but offers a bit of stick-slip which may create difficulty for extremely precise, small moves. It is far superior for dovetail or box ways where you have the potential for metal to metal contact during initial moves due to the displacement of the way lube. If you ever re-furbish a Bridgeport machine, I would definitely urge you to look into the benefits of this type of material for way construction/repair/alignment - and it is not that expensive or difficult to use.
Using rollers on cold rolled material or the round bearings (Thompson) mentioned in a previous post would be adequate for certain applications, but I have had problems with both of these methods. I previously designed a composite processing machine which used the Thompson type (round) bearings to guide a shuttle over 30' at relatively slow speeds and the rails began to exhibit signs of wear after only 8 months of use - with an automatic lubricator and dynamic loads that were less than 1/5 of the maximum recommendations. I was a bit disappointed. The second machine of similar design used THK HSR type bearing blocks (I think they were NSK or another brand) - more initial cost, but provided much longer life - and less noise....and no warranty replacement costs, so they were actually less costly in the long run. Granted this was a production machine not a hobby machine but the lesson is there.
I would venture to say that the selection depends on your goals and your budget. Each method of guiding has its place and its advantages. Each method has disadvantages of course - sometimes it is only cost, sometimes the design dictates a specific method. The selection of guiding components primarily depends on speeds, forces, accuracy requirements and budget constraints.
Guiding is no place to skimp when sitting down to design a machine in my opinion.
Keep this going - let’s hear from everyone!
newbie Quest. Basic Static Load on Linear Bearing Block kNewton ? Calico Linear and Rotary Motion 4 06-27-2007 07:10 PM
gas pipe & linear bearing dimensions relationship zoltan Linear and Rotary Motion 6 06-13-2005 04:12 PM
a cheap linear bearing mocnc DIY-CNC Router Table Machines 8 03-26-2005 05:52 PM
Linear bearing spacing & Sizing linear rails? fyffe555 DIY-CNC Router Table Machines 3 12-07-2004 02:09 PM
build your own linear bearing CNC Brute DIY-CNC Router Table Machines 4 02-07-2004 04:32 AM
