Go Back   CNCzone.com-The Largest Machinist Community on the net! > Mechanical Engineering > Linear and Rotary Motion
Linear and Rotary Motion Discuss ball/Acme screws, R&P, linear slides and theory here.
  #13
Old 05-17-2005, 02:14 AM
mxtras's Avatar
Silver Member
mxtras is on a distinguished road
Come on - anybody else?
Scott
Old 05-17-2005, 12:11 PM
DareBee's Avatar
Monkeywrench Technician
DareBee is on a distinguished road
I also have had experience (bad) of trying to use CR TGP shaft with linear BALL bearings. It was a fairly heavy load (not exceeding bearing capacity though) and I couldn't even get I stroke out of it.
The bearing balls just dug into the shaft and it was scrap (had a row of large grooves down the length).
The system probably would have worked for awhile with Oilite's or Frelon bearings due to there improved weight distribution.
www.integratedmechanical.ca
Old 05-17-2005, 05:27 PM
Moderator
Halfnutz is on a distinguished road
What is "Cr TGP" ?
Halfnutz
Old 05-17-2005, 09:11 PM
mxtras's Avatar
Silver Member
I am pretty sure it stands for Cold Rolled, Tempered, Ground and Polished.
Nice material - but it has been my dreadful, expensive experience that it is not compatible with ball bushings/bearings unless the loads and speeds are rediculously slow - even then I would suggest a different method or a hardened and chromed shaft.
Scott
Old 05-17-2005, 11:06 PM
Moderator
Wow, I had no idea. I just figured all the shiny stuff was , well, shiny. And shiny is good right? I geusse not, necessarily. But seriously, I did know Thompson's real specific about what to use, and suggests not deviating. I wonder what the cheap, well, cheaper anyway, knock off rails are. So the main difference is polished vs chromed and hardened. Thats what I love about this site. So much knoweledge.
Halfnutz
Old 05-18-2005, 12:55 AM
mxtras's Avatar
Silver Member
Turned, Ground and Polished - not Tempered. - sorry guys! I gave the material TOO much credit!
The rails made by Thompson are case hardened, ground and chromed - yes. Carbide tooling can drill them, contrary to popular opinion. Been there.
The typical "TGP" material may be shiny, but it's not hardened. It's either 1018 or 1048 steel in a normalized condition which is about 18-20C hardness. In comparison, Thompson's shafts are 60C surface hardness. The case hardened shafts from McMaster can be as high as 65C(Rockwell C scale)...not too bad in my book.
I don't know what diameter you guys use, but you may investigate these links if you haven't seen them before -
http://www.smi4motion.com/shafting.htm
http://www.metalsdepot.com/products/...dround&LimAcc=
Scott
Old 05-18-2005, 07:29 AM
DareBee's Avatar
Good research Mxtras was about to give a correction untill I read on. ;-)
IMO TGP is very reasonably priced for precision shafting - as long as soft suits your application.
damn - Paul you getting anywhere with adding a spell checker here
Old 05-18-2005, 12:15 PM
mxtras's Avatar
Silver Member
I am not knocking the TGP material - not at all. It has it's place. Just passing along info, opinion and relavant experience if any. I agree that it is reasonably priced!
I vote for the spell checker, too!! or better yet - how about speech to text instead?
Scott
newbie Quest. Basic Static Load on Linear Bearing Block kNewton ? Calico Linear and Rotary Motion 4 06-27-2007 06:10 PM
gas pipe & linear bearing dimensions relationship zoltan Linear and Rotary Motion 6 06-13-2005 03:12 PM
a cheap linear bearing mocnc DIY-CNC Router Table Machines 8 03-26-2005 04:52 PM
Linear bearing spacing & Sizing linear rails? fyffe555 DIY-CNC Router Table Machines 3 12-07-2004 01:09 PM
build your own linear bearing CNC Brute DIY-CNC Router Table Machines 4 02-07-2004 03:32 AM
