Results 1 to 3 of 3
Thread: Large Moments
    Sep 2010
    UK
    Large Moments
    Hello
    Was wondering if Igus linear rails or Bosch ecoslides are any good for cases where i have large moments (I still have no idea but a wide estimation is (20kg*9.8)*(1m to 1.5m) = Around 250 Nm)
    my options are
    1) Bosch Ecoslides largest carriage they offer
    Support it with an Extra shaft and a bearing?
    2) 2x Shafts
    3) Anything you would recommend would be nice
    Length around 1.5 meter
    Jan 2006
    I know Igus has specs on moments and setting up multiple bearings to prevent binding. I would guess Bosch has similar data. I would not recommend either system for such large moments unless you can design in a large separation between bearings to prevent binding. Linear bearings would be much better for higher loads.
    Matt
    Sep 2010
    UK
    Thanks a lot , I'll be doing more research on linear plain bearings/shafts and most probably focus on reducing weight <5kg and the distance.
    motors and gearing price for these large moments isn't encouraging
  1. Large ballscrew
    By juzwuz in forum Linear and Rotary Motion
    Last Post: 06-24-2010, 05:13 AM
  2. Large G&L retrofit
    By cdlenterprises in forum General CNC (Mill and Lathe) Control Software (NC)
    Last Post: 07-29-2008, 03:30 PM
  3. Memorable moments
    By Twistr in forum Work Fixtures and Hold-Down Solutions
    Last Post: 10-14-2005, 09:03 PM
  4. 340 or 320 with large motor
    By johnd in forum Gecko Drives
    Last Post: 05-11-2005, 04:07 PM
  5. Large servos
    By topct in forum Parts for Radio Control Models
    Last Post: 10-02-2004, 09:35 AM
