| Linear and Rotary Motion Discuss ball/Acme screws, R&P, linear slides and theory here. |
Two questions: 1.) Is a 12mm ground ballscrew with 3mm lead acceptable dimensions for a Z axis ballscrew on a router table setup? I was trying to keep my specs in the 16mm to 25mm by 4mm to 6mm range but was wondering if my range is too narrow? 2.) How "course" would you recommend going on a ballscrew for a Y axis... I see some decent ground ballscrews in the 12mm to 20mm leads (sometimes a little bigger) and since they are not in a "vertical" orientation" holding any static loads without power, (like the Z axis when the power is off) I was wondering if they would be too course. Seems they would move considerably faster than a 5mm lead, which could be a benefit... but then what impact/sacrifices do those mm ranges have on resolution and other factors... Thanks! |
| Viper... Thanks just what I was looking for... thanks for the length info. as well. Most of what I am looking at are in the 12" to 18" range for Z axis.... Still curious about the Y axs... hope someone has the same insights about them... Dave |
| Imo, 12mm or (1/2") is a very good lead for a router. You really want to be able to move as fast as possible, and the higher lead will keep your steppers spinning slower, where they have more torque. If you look in the K2 CNC thread in the commercial router forum, you'll see where Taus was trying to gear his 5 tpi ballscrews 2:1, but wasn't happy with his perforance. I suggested he gear them 1:2, which gave him about a 10mm lead, and he got much better performance.
| Gerry... Following that same thought, what do you think about a 16mm +/- diameter X/Y axis with a lead in the range of 10mm to 20+ mm? At what point do you feel the lateral or horizontal movement (speed) from a high lead screw begins to compromise the accuracy/resolution? Can the lead be "too fast" assuming feed rates, depth of cut, etc. are adjusted properly for the lead? Seems there should be a margin where the benefits of a high lead screw's speed and the torque from slower motor speeds will intersect with the accuracy/resolution... (given a tight zero backlash ballnut, etc...) Dave... Added info: Here is an example... Last edited by Dave's_Not_Here; 06-13-2005 at 10:42 PM. Reason: Added content... |
There are a lot of factors involved. What are you cutting and how fast do you want to cut it? Does you're spindle have enough power to keep up with high feed speeds? How much torque do your steppers have? If you can get higher lead screws cheaply, you can always use belts and pulleys to tune them to best work with your motors. Without additional gearing, I'd try to stay around 1/2" lead. That gives you full steps of .0025. I wouldn't want to use a higher lead unless you go with servos. The machine I'm building now will use acme screws with a 1/4" lead (1/2-8 2 start). I'm hoping to be able to cut at 100 ipm. The next machine I buils, I'd like to go twice as fast, with maybe 400ip, rapids. Using a large and fast router at work makes slower speeds really seem slow.
| With steppers, there are 200 steps per revolution. A screw with 1/2" lead needs to turn twice for 1", so 400 steps per inch. 1/400 = .0025 With higher lead screws, you start to lose resolution. A servo's resolution is dependant on the encoder, and can be changed to work with specific components. Most of the time, the servos will need to be geared to utilize their full speed range. There are formulas avialable for determining the required motor size for a given acceleration and speed. http://www.pacsci.com/support/downloads/index.html http://www.orientalmotor.com/support..._recommend.htm If I was designing a router to use a 10HP spindle, I'd want to be able to cut at at least 400ipm. We cut at 400ipm at work with a 10HP spindle, and that's the limit of our machine. I'd go faster if I could. At those speeds, you almost have to use servos, though, or you're resoution would really suffer.
Okay... so assuming I have a "goal" ralative to spindle HP, Feed Rate's, etc. Is it correct to assume that I could build the router (ball screws, servos/steppers, encoders, etc) with that target in mind and use the 3.5HP router... even though I might not get the maximum potential from the router until I upgrade the spindle... keeping in mind that I would have to adjust the servos accordingly? Guess what I am thinking, is all I want to do is upgrade the spindle... not rebuild the entire mill... ... Another off-topic question... I see a lot of pneumatic actuators and guide systems... but no one seems to be using them for CNC axis control... What are the issues, drawbacks or restrictions with these... |
#10
| Pneumatics and closed loop are compatible - there are some AWESOME positioning systems out there from Bimba, Festo etc. BUT - I would not use them for machining/routing. Air has tendency to be a little spongy. Scott
__________________ Consistency is a good thing....unless you're consistently an idiot. |
#11
| You can always use a slower feedrate with the 3.5HP router, or take lighter passes at higher speeds. You're speed is controlled in the g-code. BUild you're machine to be able to cut as fast as possible, and set up you're g-code to accomodate the spindle you're using. Depending on tooling and what you're cutting, you may be able to cut faster than you'd think.
| Ballscrew Basics | Swede | Linear and Rotary Motion | 94 | 09-06-2011 07:23 PM |
| Super simple preloaded ballscrew design - It Works! | jimjovan | Vertical Mill, Lathe Project Log | 9 | 04-25-2005 12:02 PM |
| Ground Ballscrew - No nut! | Swede | General Metal Working Machines | 4 | 11-20-2004 03:42 PM |
| Seeking router advise | ProjectCNC | DIY-CNC Router Table Machines | 7 | 11-06-2003 09:57 PM |
| ballscrew repair and some general questions | jimbo | DIY-CNC Router Table Machines | 11 | 09-27-2003 04:48 PM |
