Go Back   CNCzone.com-The Largest Machinist Community on the net! > Mechanical Engineering > Linear and Rotary Motion
Linear and Rotary Motion Discuss ball/Acme screws, R&P, linear slides and theory here.
Old 06-12-2005, 07:03 PM
SIMONSIGNS is on a distinguished road
Unhappy its huge!
Hi, plz help....I have a k2 cnc router 50 x 50 and have cut while testing it a letter T. It has cut it 99% perfectly except its 385 mm high when it should have been 57 mm high....I know its to do with the steps per mm or / inch but I don't know what it sahould be set to......does anyone know?
Old 06-12-2005, 07:21 PM
Moderator
Halfnutz is on a distinguished road
Somewhere in your controller software, in the configure axis section, you have a coeficient, usually called a scaling factor or something like that. If you increase or decrease that number proportionally, and ALL OTHER AXIS ALSO, it should make it proportianally larger or smaller. Without knowing your control package thats the best I can do. Good luck, and be glad thats your only problem. Not a big deal.
Halfnutz
Old 06-12-2005, 07:33 PM
thaks for your help.
Hi thanks for your help.... I have to have a look and try adjusting the settings....
HUGE router table musicmkr DIY-CNC Router Table Machines 19 07-16-2004 04:03 PM
Huge Thanks ynneb CNCzone Club House 5 02-17-2004 09:48 PM
HUGE Solar Storm predicted to hit today.. watch out for glitches! CNCadmin CNCzone Club House 4 10-24-2003 08:23 PM
My huge shaft! kong DIY-CNC Router Table Machines 4 08-29-2003 01:54 PM
