Results 1 to 2 of 2
Thread: Dual ball screw synchronizing
    May 2009
    How would one go about getting 2 ball screws in synchronizing vertical motion.I thinking about using as a lift.Can anyone help? Thanks!!
    Dec 2003
    If it is possible to link them mechanically then the same drive shaft for each, Ball screw jacks are nice for this such as Nook Ind.
    If it is not possible to link mechanically then a feed back device such as an encoder on each would work.
    We built a similar unit using four ball screw jacks for raising rail box-cars to allow maintenance work.
    For this, a Galil motion card was used with the gearing feature, where 3 encoders are geared of one master.
  1. Problem- Do I need mechancial synchronizing dual belt drive?
    By kiwibum in forum DIY CNC Router Table Machines
    Last Post: 05-18-2008, 11:18 PM
  2. what bearing fit with acme screw 1/2 -10(for cheap ball screw)
    By apex in forum Linear and Rotary Motion
    Last Post: 07-27-2007, 12:15 PM
  3. New technology.... old debate.....ball screw vs lead screw
    By trubleshtr in forum Linear and Rotary Motion
    Last Post: 08-15-2005, 09:42 PM
  4. Rotating Nut Ball Screw for dual X axis
    By AeroKam in forum DIY CNC Router Table Machines
    Last Post: 08-10-2005, 12:05 AM
  5. Dual Screw Axis
    By thielert in forum DIY CNC Router Table Machines
    Last Post: 11-25-2003, 11:57 AM
