Go Back   CNCzone.com-The Largest Machinist Community on the net! > Mechanical Engineering > Linear and Rotary Motion
Linear and Rotary Motion Discuss ball/Acme screws, R&P, linear slides and theory here.
  #13   Ban this user!
Old 01-12-2011, 10:50 PM
Sil_x is on a distinguished road
The hob cutter was made by turning down a piece of the lead screw on my lathe and cutting the teeth on my mill. To cut the gear I used my lathe with the hob cutter in the head and the blank on the saddle. Its pretty much like the process that Steve Bedair did on his site Steve Bedair's 9x20 Lathe Site
There are formulas for hobbing gear, I forget what they are at the moment but I remember that my 1.5 inch stock delrin was almost perfect as my blank.
I am here for the pictures.
  #14   Ban this user!
Old 01-17-2011, 10:00 AM
harryn is on a distinguished road
Hi, Thank you for the links and explanations. That is a really interesting approach to making the pinion, and other matching gears for various needs.
Supporting RanaTeckk.com and their Dashboard for MS Project promo code WRLNT-2
  #15   Ban this user!
Old 01-19-2011, 12:07 AM
Vid
Here is a vid of my machine
YouTube - minotaur CNC router
I am still trying to get the tool length probe to work so that is the reason for the multiple attempts on the cut
  #16   Ban this user!
Old 02-22-2011, 06:51 PM
quazga's Avatar
quazga is on a distinguished road
Yeah I know what you mean by having too much fun. Having CNC capability is like going from the Flintstones to the Jetsons! HAHAHA! =D
Great work!
  #17   Ban this user!
Old 02-23-2011, 06:26 PM
I can agree with that.
A few notes on the gear material. After about a month of use the epoxy resin i used has started to chip and crack. I am trying a softer and hopefully more wear resistant urethane casting.
I did hob a few gears out of aluminum for my X axis but even though I tried to get them identical, some raking occurred due to the differences in circumference. They work great on my Y though.
Name:	SNC12170 (Medium).JPG‎
ID:	127249   Click image for larger version
Name:	SNC12174 (Medium).JPG‎
ID:	127250   Click image for larger version
Name:	SNC12177 (Medium).JPG‎
  #18   Ban this user!
Old 02-28-2011, 01:01 PM
Mike Everman is on a distinguished road
I of course love the screw rack idea. I say of course because I've put some effort into it in the last few years, off and on.
Making pinions out of steel was not particularly difficult when you make a simple tool.
Blanks are put in this fixture and a spiral flute tap used to make two at a time. It is not as perfect as hobbing, where the ratio of tap rotation to pinion rotation would be tightly controlled, but it works well. Plastic would be doable with a hand drill and just two pins in a plate at the right center distance.
You just need to calculate the pitch diameters of screw and pinion, such that the pinion pitch is an even number of teeth (obvious, I know, but if side cutting just one you can feed toward the center until you find a spot where the teeth look good; in this case I've nailed the center distance, and machine two at a time so there is no side load on the tap.)
ID:	127724   Click image for larger version
ID:	127725   Click image for larger version
ID:	127726   Click image for larger version
Mike Visit my projects blog at: http://mikeeverman.com/
http://www.bell-evermannews.com/ http://www.bell-everman.com
  #19   Ban this user!
Old 02-28-2011, 04:23 PM
Very nice, I like the simplicity of your fixture!
Tags
acme screw rack pinon r&p
ACME screw opinion SScnc DIY-CNC Router Table Machines 26 06-04-2011 06:13 PM
what bearing fit with acme screw 1/2 -10(for cheap ball screw) apex Linear and Rotary Motion 4 07-27-2007 11:15 AM
ACME screw questions Lionclaw DIY-CNC Router Table Machines 9 01-30-2006 06:16 PM
acme screw streses?? mrbaseball Linear and Rotary Motion 6 11-11-2005 02:43 AM
acme screw to ball screw question Billw DIY-CNC Router Table Machines 9 07-18-2005 12:10 AM
