Go Back   CNCzone.com-The Largest Machinist Community on the net! > Mechanical Engineering > Linear and Rotary Motion
Linear and Rotary Motion Discuss ball/Acme screws, R&P, linear slides and theory here.
Old 06-09-2005, 03:16 AM
Dave's_Not_Here is on a distinguished road
Anyone looking for a Precision ground ball screw...
...with a rotating nut on a fixed shaft? Table moves with nut...
Here is a little goodie...
http://cgi.ebay.com/ws/eBayISAPI.dll...tem=7521941562
Old 06-09-2005, 09:30 AM
Al_The_Man's Avatar
Execpt it looks like they have listed it as the precision version when it is a rolled screw version, if the nut is not pre-loaded, they are prone to have a little backlash.
Old 06-09-2005, 09:39 AM
mxtras's Avatar
Silver Member
mxtras is on a distinguished road
I saw this earlier in the week -
Did you notice that the info seems inaccurate? It says it's a .25 pitch but it is a 4 start screw if it moves 1" per rev, right? I would call that a 1" pitch screw.
Scott
Consistency is a good thing....unless you're consistently an idiot.
Old 06-23-2005, 10:33 AM
scotty_weeks is on a distinguished road
Scott,
Actually that would be correct. If it is a .250 pitch and a 4 start lead that would be .250 x 4 = 1.00. The ballnut has a 1" pitch single ballcircuit. So actually it is four 1" pitches rather than a .250 pitch.
This type of ball screw allows you to simply remove the nut and start it on another lead when the screw gets worn out. These are usually a non-preload nut used only for actuation purposes such as opening covers or doors.
Scotty
Ballscrew Basics Swede Linear and Rotary Motion 94 09-06-2011 07:23 PM
Ball Screw Identification BeerFizz Benchtop Machines 2 04-07-2005 11:28 AM
Need help with Ball Screw Choice samualt DIY-CNC Router Table Machines 5 09-06-2004 08:02 AM
Ball Screw or Lead Screw? Which is Better? ljoe1969 DIY-CNC Router Table Machines 4 07-28-2004 09:49 AM
Ball screw size/pitch? jakk100 DIY-CNC Router Table Machines 7 06-18-2003 11:21 AM
