Go Back   CNCzone.com-The Largest Machinist Community on the net! > Mechanical Engineering > Linear and Rotary Motion
Linear and Rotary Motion Discuss ball/Acme screws, R&P, linear slides and theory here.
Old 05-25-2005, 05:35 PM
Gold Member
InspirationTool is on a distinguished road
THK Slide pack FBW? Cheaper linear system?
So I was poking around THK's site, and I see this:
http://www.thk.com/technical/download/f.html#3
It looks to be a precision ball bearing "drawer slide" with max clearance of .1 mm (.004")
They are billed as "low cost" as compared to the linear rail stuff.
Sounds like it would be just the thing for a CNC router... Is there a reason I've never seen this in all the pictures of home build CNC machines?
Thanks!
-Jeff
Old 05-25-2005, 06:21 PM
mxtras's Avatar
Silver Member
mxtras is on a distinguished road
I designed and built an assembly machine (actually an elaborate fixture) for Rockwell about 8 years ago using these. I was not blown away with the performace, but it was adequate for it's purpose. The motion was a bit notchy - not as smooth as a linear bearing, of course, but I think it might be a reasonable option as long as you don't ask it to handle loads in two directions - use multiple sets to eliminate vertical loads on the carriage. In other words, if you load the carriage straight down (perpendicular to the rail) it will dramatically increase the rolling resistance and stretch the rail open.
Personally - I wouldn't use them for a router.
Just my opinion....you know what they say about opinions.
Scott
Revolutionary Linear Drive System allanconway2 Polls 21 05-03-2009 09:27 PM
CNC Glossary CNCadmin CNCzone Club House 17 03-09-2008 04:08 PM
T-Slot Linear Slide question audball22386 80/20, TSLOTS and other Aluminum Framing Systems 1 03-04-2005 02:19 AM
Your advice please on this Linear Rail system Moondog DIY-CNC Router Table Machines 9 10-13-2004 09:14 AM
Inexpensive Linear Slide Assemblies? Homl DIY-CNC Router Table Machines 15 06-03-2004 02:05 AM
