Results 1 to 3 of 3
Thread: Is there such a thing as too much torque?
    Jun 2010
    I'm starting a plan for a wood/aluminum cutting machine. The price b/w a nema 23 and 34 isn't that significant for me. I've already got a gecko 203v. Is there anything down side to going with the nema 34 just to have that extra power?
    Oct 2009
    I'd go with Nema 34, you can't really have too much torque unless you're shredding gears and such. A Nema 34 sized motor shouldn't be doing that unless your entire machine is made from plastic. Even then you don't have to use all the available torque.
    Mar 2003
    Shelby Twp, MI....USA
    Depends on the specific motor, but typically, Nema 23's will spin faster than Nema 34's
    It's actually possible that the 23 will have more torque at higher rpm than the 34.
    You need to look at the rpm you'll be using, and how much torque each motor has at that rpm. Holding torque is measured when the motor is not spinning. Having more torque when the motors aren't moving may not be much help.
  1. Constant Torque vs. Varaible Torque VFD
    By robhrzic in forum Phase Converters and VFD
    Last Post: 02-16-2012, 08:46 PM
  2. Holding torque vs rotational torque ?
    By SScnc in forum DIY CNC Router Table Machines
    Last Post: 05-06-2010, 08:41 AM
  3. Did we do the right thing?
    By Crispymetal-fab in forum General CAM Discussion
    Last Post: 04-23-2009, 09:07 AM
  4. Where do I put this thing?
    By Sal@TKL in forum General Metalwork Discussion
    Last Post: 04-17-2007, 11:25 AM
  5. what is this thing for?
    By bigal in forum General Electronics Discussion
    Last Post: 07-08-2005, 08:05 AM
