Go Back   CNCzone.com-The Largest Machinist Community on the net! > Mechanical Engineering > Linear and Rotary Motion
Linear and Rotary Motion Discuss ball/Acme screws, R&P, linear slides and theory here.
Old 05-12-2010, 12:06 PM
swisspnp is on a distinguished road
Precision - Shaft or Rail?
Question for all you pro CNC builders.
I am building a CNC to do pick and place of circuit board components, however I've come up blank when choosing between shaft and rail systems.
Does one offer more precision than the other? I'd assume not otherwise one would always be used over the other? Or does one cost more?
I'm looking to find out which system you would use for the highest accuracy possible from a homebrew machine.
And do I need two sets of each in on each side of the axis? Or will just one suffice?
Many Thanks!
Edit: Perhaps its worth mentioning I will also want to mill aluminium on this machine..!
Old 05-12-2010, 05:24 PM
Roller rails (more expensive) will produce better accuracy and rigidity. Round shafting (less expensive) lower rigidity.
Dick Z
DZASTR
Old 05-12-2010, 05:28 PM
ah ha! So if I can afford the linear rails I shall get those.
Thank you.
Quick question:
When using rails, should I use two on both axis, like in pairs?
eg:
Old 05-13-2010, 07:34 AM
The pairs configuration is what is normally employed. Occasionally a very wide rail with a long bearing slide is possible.
Dick Z
DZASTR
The SyiL x7 linear series,strong spindle,precision rail lines,rich features. syil Product Announcements & Manufacturer News 90 11-09-2010 03:07 AM
Hollow shaft linear rail GLynnC Want To Buy...Need help! 2 02-14-2010 07:27 AM
1045 precision ground shaft deflection elogicca Mechanical Calculations/Engineering Design 5 02-06-2007 01:14 PM
RFQ: Precision Gear Shaft ncmrfixit Employment Opportunity 5 11-15-2006 07:24 AM
Will 63" long Rail sag without using shaft support? starCNC General Metal Working Machines 5 08-04-2004 08:29 AM
