| Linear and Rotary Motion Discuss ball/Acme screws, R&P, linear slides and theory here. |
| Can we help Ito (Stepper screw coupling issues) Today I recieved this PM.
Thanks |
| Ito, I just found this in the photo gallery. ![]() EDIT: all of a sudden it has been removed from the phot gallery. I wonder why? Last edited by ynneb; 05-12-2005 at 08:44 AM. |
| Could work: If i make a homemade "lovejoy" ? i will use 20mm diam NYLON and some floppy disk parts. see the pics. What do you think? Ito. |
| Opps, one more picture... |
| Ito, Try taking a short piece piece of rubber hose the size of the motor shaft or the scre shaft. Automotive gas or vacuum line will work. The on the other side make a nylon piece the size of the other shaft. Use automotive hose clamps to secure. Phil
__________________ Phil, Still too many interests, too many projects, and not enough time!!!!!!!! Vist my websites - http://pminmo.com & http://millpcbs.com |
| What you just drew is a homemade U-Joint, like the one in your socket wrench set. It'll probably work, but you might want to mock it up and see how much flex is present in it. I think the hose coupling is a much better, and definitely simpler method for shafts of even remotely similar size. -- Chuck Knight |
| The rubber hose idea may sound crude, but in practice it works rather well, especially for a lighter hobby use table.. I did this one as a 'temporary' joint, and haven't found any reason to upgrade it yet.. the red rubber hose is from an auto air conditioning recycling unit, just under 1/4" , and is fairly well reinforced with virtually no twist, easy to cut, and the clamps are single use crimp clamps, again designed for air conditioning ewuipment, and just crimp tight with a pair of end cutters.. the stepper ouput shaft is 1/4" and the all thread rod is 1/4x20tpi, at least the rod is one step above 'cheap' grade... sorry about the poor photo.. |
| Is that the correct type? It is used on air pressured... Thanks a lot! The entusiasm came with full power! |
| I would suggest turning the ends to a diameter such as 1/4" and getting some real couplers from mcmaster, I use the helical beam couplers for my cnc kits, I got a couple spider couplers, those have a small amount of play but will work just fine unless your using absolutely zero backlash screws. Jon |
#10
| Well, i wish i have money to get real stuffs to my machine... As you know, heare in 3rd world thing are so much more expensive. Multiply by 3 or 4 the costs. I bought today the rubber hose. I worked 4 hours on the new coupling system. It seems to be OK !Tomorrow i will make a test, but moving by the fingers i can see the rubber hose work, really amazing. I should made this at first time... The mounting stoped as the pictures show. Thanks guys, you are good guys !!!!! |
#11
| Way to go ITO ! Phil
#12
| I an happy for you mate, you have made a great effort of your machine ![]() Thanks for posting the pictures |
| stepper coupling | Maximebleu | Mechanical Calculations/Engineering Design | 1 | 05-14-2005 03:24 AM |
| Attaching a Stepper | andy_ck87028 | DIY-CNC Router Table Machines | 4 | 12-24-2004 12:09 PM |
| Build a CNC Router - FAQ | samualt | DIY-CNC Router Table Machines | 7 | 04-13-2004 09:55 AM |
| coupling motor to lead screw ideas? | fyffe555 | DIY-CNC Router Table Machines | 4 | 09-15-2003 12:18 PM |
