| Linear and Rotary Motion Discuss ball/Acme screws, R&P, linear slides and theory here. |
I was holding a couple of roller bearings on a threaded rod while moving them to another location and when I took them off I noticed that the last one flipped sideways as much as it could and became stuck on the threads. so I tried turning the rod while applying pressure to this and I found that the threads actually hold true to the ridge or sharp corner of the inner race of the bearing. so I am wondering if this could be applied in a practical manner a simple way of showing this would be this ---/--- the slash (/) is the bearing and the dashes (---) would be the threaded rod my idea is to turn several of the bearings in different directions and use a pair of plates with small curved grooves cut into them then the plates could be pressed together with a set of screws on the corners to apply the desired pressure( enough to make the edge of the inner race catch on the threads tightly but not bend the threaded rod) so in the end it would look something like this: __________________ . |. . . . . . .. . . . .| -|--\---/---\---/--|--- _|______________|_ or this: __________________ . |. . . . . . .. . . . .| -|--/---/---/---/--|--- _|______________|_ (ignore the periods as the forum would not let me string up a bunch of empty spaces has anyone already tried this? if so a link to their attempts? |
| Sounds similar to this thread: http://www.cnczone.com/forums/showthread.php?t=66381
__________________ Bill |
| screw nut, bronze or delrin slide ... concept | turpija | DIY-CNC Router Table Machines | 2 | 12-05-2009 03:26 AM |
| ball screw rebuild or replace Roboform 400 | jetski | EDM Machines | 0 | 08-07-2009 08:33 AM |
| what bearing fit with acme screw 1/2 -10(for cheap ball screw) | apex | Linear and Rotary Motion | 4 | 07-27-2007 11:15 AM |
| Belts to replace long ball screws? What are your thoughts?? | runinbymdnt | Linear and Rotary Motion | 11 | 02-17-2007 04:31 PM |
| New technology.... old debate.....ball screw vs lead screw | trubleshtr | Linear and Rotary Motion | 1 | 08-15-2005 08:42 PM |
