Go Back   CNCzone.com-The Largest Machinist Community on the net! > Mechanical Engineering > Linear and Rotary Motion
Linear and Rotary Motion Discuss ball/Acme screws, R&P, linear slides and theory here.
Old 03-22-2010, 10:20 PM
oxford's Avatar
oxford is on a distinguished road
timing belts that don't cog
Are there timing belts that don't cog?
Do HTD belts cog less than trapezoidal toothed shaped belts?
Old 03-23-2010, 10:37 AM
I don't think you can be absolutely free of "cogging".
The newest belts, like Gates GT2 are about state of the art right now. They have a carbon fiber belt that doesn't stretch after initial run-in.
Be sure to use a pulley with matching grooves for the belt tooth profile.
Dick Z
DZASTR
Old 03-23-2010, 11:48 AM
DareBee's Avatar
Monkeywrench Technician
DareBee is on a distinguished road
AFAIK the GT2 is pretty much the same as the HPD and both have a miniscule amount of "cogging".
You will pay for them though.
www.integratedmechanical.ca
Old 03-23-2010, 11:00 PM
Per Gates catalog "PowerGrip GT 2 belts must run in PowerGrip GT 2 sprockets. PowerGrip GT 2 belts are not compatible with PowerGrip HTD sprockets, or any other sprockets on the market."
HTD sprockets have greater clearance for the belt teeth. HTD teeth have a different profile than GT 2's which have little or no clearance. GT 2 teeth have an involute form similar to gear teeth, which makes for smoother engagement and disengagement with the sprocket.
Dick Z
Add: You may find Gates' belt/sprocket interchange brochure informative. It compares Gates belts to their own sprockets as well as others proprietary tooth forms.
DZASTR
Old 10-18-2010, 03:18 PM
surfit is on a distinguished road
Does anyone know where I can find the gt 2 power grip pulley tooth profile specs? I looked on thier website but they are not published. They have the O.D. and the pitch diameter but thats it.
Old 10-18-2010, 03:34 PM
Al_The_Man's Avatar
Did you check out GoodYear Eagle pd style?
Goodyear® Engineered Products :: Eagle NRG
They are available at alot of suppliers.
Old 10-18-2010, 03:57 PM
Check prices on the Eagle pd's. $$$$$$$$$$$$$$$
Dick Z
DZASTR
Old 10-18-2010, 04:32 PM
I want to machine the pulleys myself I plan to have a form tool made to use on a fourth axis to index the number of teeth needed.
New here and Timing Belts Shane Neifer CNCzone Club House 0 10-13-2009 01:53 AM
Timing Belts kingpav Linear and Rotary Motion 1 09-28-2008 09:54 PM
Timing belts CAM_MAN DIY-CNC Router Table Machines 11 04-13-2006 12:24 PM
Timing belts, why not use? wwminc Linear and Rotary Motion 10 09-03-2005 10:03 PM
Timing Belts chas DIY-CNC Router Table Machines 1 01-19-2005 09:03 AM
