| Linear and Rotary Motion Discuss ball/Acme screws, R&P, linear slides and theory here. |
I found some ABEC-7 (best accuracy) bearings that are originally for skateboards. They are about $1/each. See the web link below. I plan to use these bearings to build my own bearings & sliding rails. It has a 3.25 KGF dynamic load. My question is what is the load ratings in LBS (US pounds)? Can these bearings handle a 5' x 5' metal mill used to cut steel and aluminum? How do they compare with bearings normally used for metal CNC mills? http://www.vxb.com/page/bearings/PRO...57e70856323141 |
| One kgf is equal to 2.2 pounds, so 3.25kgf is a little over 7 lbs. I would say that something is wrong with those specs. Using those specs, a skateboard with 4 wheels and 2 bearings per wheel would be rated for less than 60 lbs, not enough to support a large child even standing still. |
| That is a good price for those sealed bearings. Regardless of those numbers, I would go ahead and use them. I wonder if they meant those as an axial load. I bet if you look up a standard 608 bearing that you could get an actual rating. Besides most of your loads will be of a radial nature anyway.
__________________ If it's not nailed down, it's mine. If I can pry it loose, it's not nailed down. |
| coolman, try these bearing same price and can take a lot more pressure. 1080 lbs static 2148 lbs dynamic it has 17 mm shaft size. http://www.vxb.com/page/bearings/PRO...8e55c4d91caa4c |
I am using those abec-7's on my plasma table. I have used 4 bearings to support the downward weight of my gantry, which at the moment weighs 45kg, or 100lbs. From memory these bearings can handle about 90kg each i think. Hey, I was sitting on my gantry the other day because I was so excited about actually making the gantry and how good it slides along. I weigh 100kg the gantry weighs 45, so say 150kg which is probably around 330lbs and I tell you what, unbeleviable! I could easily push myself along while I was sitting on the gantry. COOL! Apples |
| Ballscrew Basics | Swede | Linear and Rotary Motion | 94 | 09-06-2011 07:23 PM |
| ABEC Skate Bearings | andy_ck87028 | Mechanical Calculations/Engineering Design | 3 | 01-26-2005 08:07 AM |
| Are VXB.com bearings good? | Evilness | DIY-CNC Router Table Machines | 7 | 07-16-2004 12:39 AM |
| The truth about skateboard ball bearings | Swede | DIY-CNC Router Table Machines | 24 | 04-16-2004 06:21 PM |
| router bearings | pminmo | DIY-CNC Router Table Machines | 8 | 06-14-2003 12:32 AM |
