Go Back   CNCzone.com-The Largest Machinist Community on the net! > Mechanical Engineering > Linear and Rotary Motion
Linear and Rotary Motion Discuss ball/Acme screws, R&P, linear slides and theory here.
Old 03-09-2010, 01:22 AM
15mgtar is on a distinguished road
please help with ball nut problem
I got a big problem on my ball nut that is mounted vertically on my Z axis. After a while the little ball bearings would simple drop off from the ball nut ( i use fsi type ball nut) can someone please give me the solution to this?
Old 03-09-2010, 03:11 AM
PEsystem is on a distinguished road
Smile
do you have pictures of your ball nut? I have ball nut too, but not same as yours. if you have picture, maybe I will give you some suggestions. my email address: bluelion2618@163.com
Old 03-09-2010, 03:38 AM
I mount the fsi ball nut vertically and after several days of work the little bearings would come out from the back side of the ball nut ( because the teflon ring got crooked)
ID:	102394   Click image for larger version
Old 03-09-2010, 10:07 AM
hmotion is on a distinguished road
Ballnut problem
The teflon ring got crooked because the balls came out, not the other way around. This was probably caused by not loading the ballnut correctly on the screw when it was assembled or that the nut got run off of the screw enough that some balls came out of the cross-over button circuitry. Either way, this configuration ballnut/screw is not a good one to learn on. I would strongly suggest that you take it to a ballscrew repair facility for a bearing ball reload.
Problem- X3 conversion - ball nut problem jlerion Benchtop Machines 1 08-03-2009 11:09 PM
ball screw problem endgrainguy Linear and Rotary Motion 4 05-23-2008 05:42 PM
ball bearing problem clachan Syil Products 2 08-23-2007 12:13 AM
Big Ball Screw & Ball Nut mistake. Jack F General Metal Working Machines 12 04-28-2006 10:53 PM
Ball Nut Problem kaderick Machine Problems, Solutions , Wireless DNC, serial port 1 11-18-2004 12:25 PM
