Go Back   CNCzone.com-The Largest Machinist Community on the net! > Mechanical Engineering > Linear and Rotary Motion
Linear and Rotary Motion Discuss ball/Acme screws, R&P, linear slides and theory here.
Old 03-08-2010, 12:59 PM
patriqq is on a distinguished road
Use Pillow Blocks or Machine my own Housings?
Another question for my dual round-shaft assembly.
What concerns arise with machining bearing housings (instead of using pillow blocks)?
I assume the bore locations have to be spot-on. ±0.001" ? ±0.0005" ?
I also assume the recess for the retaining ring is tricky/expensive to machine. Any shortcuts?
thanks
Old 03-11-2010, 05:03 PM
loka is on a distinguished road
i assume you are going to use open type bearings with support rail.
H7 or J7 are pretty common for this type of housing bore.
some housings have slot with thread on it so you can adjust the radial clearance.
but it makes much more sense to just buy bearings as a set.
if for some reason you are using unsupported shaft and closed bearing, using flanged bearing makes housing simple. you don't need much accuracy on bore and flange can be mounted with screws.
Seen these on TradeMe - linear bearings with pillow blocks cncmachinemad@g Australia, New Zealand Club house 2 10-22-2009 01:22 AM
Just IN- PBC Linear Slides out New Stainless Steel Pillow Blocks Pacific Bearing Product Announcements & Manufacturer News 0 09-04-2009 03:01 PM
PBC Linear Slides out New Stainless Steel Pillow Blocks Pacific Bearing Product Announcements & Manufacturer News 0 08-26-2009 03:50 PM
1/2" pillow blocks pbunnstf General Metalwork Discussion 2 08-11-2006 09:30 PM
Making your own pillow blocks and Rail mounts? Zephrant DIY-CNC Router Table Machines 20 05-19-2003 06:34 PM
